Well here is my repair process...
This was the part to be bonded originally...
And recall that this was the other side:
So I scuffed with 100 grit paper... I had 60 and 100, though I've seen 80 recommended. So I went with 100 to get more surface area.
I wiped it with denatured alcohol and then flame licked the parts.
Be aware that its pretty easy to get the parts to start to burn. I almost had that!
i drove to McMaster Carr yesterday to buy the proper 3M stuff. Its the only stuff Ive seen out there truly recommended for PP. It was a $32 tube, so a fairly costly gamble for a $245 part, but the highest chance of success IMO.
It is gritty stuff. Didn't look at the MSDS but Id guess it is silica or something similar. Fairly large particles for doing small gaps, but Im sure they optimized it...
Instructions say max strength after 12 hours at 77F, so I left it a good deal longer then that, then installed the part back onto the car.
Screwed it down without any issue and it seems to be holding just fine.
The 3M stuff is interesting. It has a very high holding strength on low surface energy plastics like PP, but it also is not cured as hard as I thought it would. I was expecting a very solid hard plastic structure, but there was still some give and softness to this cured pile of product that I had mixed.
Its stinky stuff, and they recommend just dripping some out before the quantity you want to use. Even that had somewhat self-mixed and begun to cure.
I may turn all this into a DIY.
So far, so good...
