Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
biyogo, Jandry, BlueKelah, threeeightteen, TOADchunks
56891 Registered Users
56 registered (aquariuscsm, Atesz792, 2009Edge, B767capt, AlienBug, 04SE, 6 invisible), 838 Guests and 152 Spiders online.
56891 Members
66 Forums
244533 Topics
#3354692 - 04/27/14 02:11 PM AC Delco Wiper Blades?
Volvohead Offline
Loc: SE Pa
Haven't used these in a while.
Time to pop off the winter blades of our truck, and I don't like the chain store options.
Ours takes the 8-2221.
Anybody running Delcos, and how do they fare?
#3354698 - 04/27/14 02:15 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
Turk Offline
Loc: MN
Yes, that's all I run in 4 vehicles.
Excellent. thumbsup
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3354735 - 04/27/14 03:05 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
BlindBaby Offline
Loc: WV
Are the AC Delco blades OEM, if so, where can they be purchased?
It seems as if the factory blades outlast anything I purchase over the counter.
#3354742 - 04/27/14 03:22 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
46Harry Offline
Loc: hawthorne, Ca.
I've been buying Delco blades from Rock Auto for a few years. They have good prices on original Delco blades.
#3354767 - 04/27/14 03:47 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
Volvohead Offline
Loc: SE Pa
Sounds like the Delcos are OK.
That's what we'll get.
I'm not sure these are what the factory or dealers fit, as they have a separate GM part no. and is packed in standard GM parts fashion. Also about $5-6 more per blade.
#3354850 - 04/27/14 05:15 PM Re: AC Delco Wiper Blades? [Re: BlindBaby]
user52165 Offline
Loc: CA
Amazon. I've had good luck with Delco also.
#3354895 - 04/27/14 06:07 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
Rhymingmechanic Offline
Loc: VA
AC Delco has several different lines, so be sure to get the OEM line. I ordered the "Advantage" beam wipers from Rock Auto for my Vibe, and they contacted each other when installed. I was past the return window, so I had to run one new and one old together.
The Advantage also didn't wipe for anything in this application, so I finally ordered an new pair of OEMs from an online GM supplier. They're just like the originals, and wipe perfectly. (The AC Delco rear blade for this car looks just like the Trico Exact Fit from Advance, but nothing local looks like the front ones.)
#3355281 - 04/28/14 03:53 AM Re: AC Delco Wiper Blades? [Re: Volvohead]
Falcon_LS Offline
Loc: Kuwait
I'm running the OEM line on two of my vehicles - I'm very happy with them. thumbsup
99 Explorer EB: M1 0W40/FL1A
00 Pajero: M1 0W40/26300-35503
01 Marquis: M1 ESP 5W30/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: M1 ESP 5W30/M1-206
#3355715 - 04/28/14 02:45 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
Volvohead Offline
Loc: SE Pa
These are their "Professional" line, which is their higher grade.
If they don't work out, I'll let everyone know.
I'm expecting 2 strong years, as I run winter blades half the year on this one.
The Anco winter blades coming off were surprisingly good, and I think I can squeeze another season out of them, too.
#3355774 - 04/28/14 03:47 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
Gokhan Offline
Loc: Los Angeles, California
Ideally I like OEM wiper blades with replaceable rubber inserts. It's faster and cheaper to replace and there is much less waste. The only part in the wiper blade that wears out is the rubber; so, there is no point in replacing the whole thing unless they don't make refill inserts.
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
#3355880 - 04/28/14 05:23 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
hattaresguy Offline
Loc: CT
Bosch Icon.
#3355918 - 04/28/14 05:45 PM Re: AC Delco Wiper Blades? [Re: hattaresguy]
Volvohead Offline
Loc: SE Pa
It's a truck. The perfect edge on the Bosch will get chewed up in no time.
Tried them on a couple of Volvos, though. They're good blades, but the OEM Valeos hold up longer for about the same price.
On the R129, I use the one blade the Mercedes dealer gave me when I first bought it. It makes one wipe per year, at inspection time.
#3356207 - 04/28/14 09:16 PM Re: AC Delco Wiper Blades? [Re: Volvohead]
hattaresguy Offline
Loc: CT
I do use them on my truck, average service life seems to be somewhere in the 3-5 year range.
Not seeing how it matters, maybe if you go mud bogging a lot they get chewed up?
Edited by hattaresguy (04/28/14 09:16 PM)
#3359608 - 05/02/14 08:42 AM Re: AC Delco Wiper Blades? [Re: Volvohead]
BlindBaby Offline
Loc: WV
I can find every type of Delco blades on Amazon other than OEM.
