Mother in laws 2002 Saturn SL1 w/ 65k on the engine. 6k on Valvoline NexGen 5W30, Purolator filter. Doesn't burn any oil. I usually do 5k oil changes.
From Blackstone:
Universal averages show typical wear levels for this type of engine after about 4,000 miles on the oil.
Most of the metals are right in line with universal averages. Iron is perhaps a bit high, even for 6,000 miles on
the oil, but it's not really enough to be concerned about the steel parts like cylinders and rotating shafts. We'll
see how it looks next time. The oil itself is in fine shape. The viscosity is on the mark for 5W/30 and no fuel or
coolant was found. The TBN read 1.3, showing a little active additive. Try 8,000 miles on the next oil and
check back.
Alum 5
Chrom 1
Iron 32
Copper 5
Lead 0
Tin 3
Moly 106
Nickel 0
Mangan 1
Silver 0
Titan 0
Potass 7
Boron 13
Silicon 15
Sodium 247
Calcium 2028
Magnesium 9
Phosphor 613
Zinc 745
Barium 0
SUS Vis 56.2
cSt Visc 9.13
Flashpoint 390
Fuel .0
Antifrz 0
Water 0
Insolub. .2
TBN 1.3
From Blackstone:
check back.
Alum 5
Chrom 1
Iron 32
Copper 5
Lead 0
Tin 3
Moly 106
Nickel 0
Mangan 1
Silver 0
Titan 0
Potass 7
Boron 13
Silicon 15
Sodium 247
Calcium 2028
Magnesium 9
Phosphor 613
Zinc 745
Barium 0
SUS Vis 56.2
cSt Visc 9.13
Flashpoint 390
Fuel .0
Antifrz 0
Water 0
Insolub. .2
TBN 1.3
