How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
06/27/16 09:41 PM
Carpet cleaning methods.
by Run
06/27/16 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
06/27/16 09:26 PM
Emtrac Plus Battery
by Tapan
06/27/16 09:25 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
22 registered (edhackett, car51, Bill_G, bbhero, ac_tc, 1 invisible), 709 Guests and 11 Spiders online.
58295 Members
66 Forums
250917 Topics
#3353000 - 04/25/14 03:13 PM Adding Lubro Moly Oil saver will increase grade?
Yannick Offline
Loc: Montreal,Quebec,Canada
Hi,
By adding one can of Lubro Moly Oil saver in 5liters of 10w30 , will change the grade to what approx? 15w40?
thks
#3353073 - 04/25/14 04:24 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
dave5358 Offline
Loc: North Bend
Originally Posted By: Yannick
Hi,
Liqui Moly Oil Saver (fka Lubro Moly Oil Saver) shouldn't change the grade at all. From the manufacturer's website, it says:
Regenerates rubber and plastic engine seals such as shaft seals and valve stem
seals and prevents oil stains under the vehicle. Counteracts oil dilution. Reduces
engine noise and oil consumption through piston rings and valve guides.
It swells rubber seals or at least makes them more pliable.
You may be thinking of Motor Honey or STP?
2006 Forester XT
2008 Corolla LE
#3353140 - 04/25/14 05:44 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
Falcon_LS Offline
Loc: Kuwait
Motor Oil Saver is an ester-based additive. It will thicken up the oil slightly, but nothing major.
99 Explorer EB: GC 0W40/FL1A
00 Pajero: Aisin PAO/Ester 5W40/MD352626
01 Marquis: GC 0W40/FL820S
03 Expedition: M1 0W40/FL820S
05 Envoy: GC 0W40/M1206
#3353150 - 04/25/14 05:52 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
Yannick Offline
10-4 Boss !!!
#3353158 - 04/25/14 05:59 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
147_Grain Offline
Loc: USA
A VOA of Lubro Moly a few years ago showed viscosity characteristics similar to a 5W-30.
Here's an example from 2008 VOA:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1234989
#3353169 - 04/25/14 06:12 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: 147_Grain]
dailydriver Offline
Loc: Bucks County, Pa.
We are talking about the Motor Oil saver in this thread, NOT the MOS2.
The Motor Oil Saver IS one of the most viscous additives I've ever seen anywhere (even more so than the old VSOT stuff), but, as has been stated, adding 300ml of it to 5+ quarts of oil will not do much to change the HTHSV, nor the cSt @100*C. wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3353186 - 04/25/14 06:26 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
147_Grain Offline
Loc: USA
Oops! frown
#3353312 - 04/25/14 08:33 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: Yannick]
Yannick Offline
got it !
#3354271 - 04/26/14 10:33 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: dailydriver]
HTSS_TR Offline
Loc: Lake Forest, CA
What I observed is different with yours, VSOT is much thicker than Lubro Moly Oil Saver.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3354791 - 04/27/14 04:08 PM Re: Adding Lubro Moly Oil saver will increase grade? [Re: HTSS_TR]
dailydriver Offline
You are probably correct on this as I have not handled the VSOT product in MANY years now, and have forgotten just how 'frozen molasses-like' that stuff was. wink LOL
M1-206 oil filter
