Best Hand Pump
Mityvac MV7201 was $6x about 7-8 months ago on Aamzon.com, now it's $8x.
A good fluid extractor is useful for these: change oil, ATF, bleed brake ...
I am considering the "Hydro-Turf Oil Extractor OIL01" sold at Amazon because the pump has a large volume and it holds 6L of fluid. It's also priced around $50 and quite affordable compared to a mightyvac. A Mercedes guy on youtube did a review on some budget fluid extractors and this one looks like a good piece of equipment.
A turkey baster is only a couple of bucks, but the wiffy might give you a real bad time if you steal hers LOLZ.. They work but are kinda messy unless you add a small hose to get it in more places.
For power steering fluid, just get an old pump from a shampoo bottle and use that. Probably not efficient for the trans fluid, though as it would take way too long.
Not sure (even if you wanted to spend the time) would the pump you mention have enough suction to go the 20" to 30" into the transmission.
