Originally Posted By: 147_Grain
demarpaint:
I appreciate your contributions on this fine Forum and agree that the technicians at Liqui Moly should be on the same page, but there is enough data to give us a general idea that the products perform as advertised.
To summarize things from my perspective, I dug-up the following e-mail from Liqui-Moly of Germany last summer:
Quote:
To:
Sent: Friday,
June 7, 2013 4:44:33 AM
Subject: Antwort: WG: Questions About Cera-Tec and Lubro-Moly MoS2
Hello Mr. ......
Sorry for being so late but I've had problems with me account.
Concerning your question about the CERA TEC - this is the best friction modifier we have at the moment. It's specially developed for aluminum based engines to protect the surface by chemical agents and solid lubricants.
We recommend a ratio of 5% - 6% because there may be an influence on the additive package of the oil. In combination - 5000 miles oil changing intervals and CERA TEC - I suggest the usage of CERA TEC at the first oil change and the usage of MoS2 based friction modifier the next 2 oil drains (to fill up the loss of the solid lubricant particles with the oil). The chemical component of the CERA TEC will stay in the surface for a long time and so you don't need to replenish it at every oil change.
The solid lubricant in both products protects the surface of the engine at every condition (specially in extreme conditions where the oil isn't able to build up a stable lubrication - engine starting - lubrication at the first moment, extreme pressure and hot conditions).
I hope I could help you and sorry again for the late answer.
Best Regards from Ulm
I. A.
Harry Hartkorn
Anwendungstechniker
Application Engineer
Phone: +49 731 / 14 20 - 895
Mobile: +49 172 / 7 24 84 85
Fax: +49 731 / 14 20 - 44895
LIQUI MOLY GMBH
F & E / Anwendungstechnik
Jerg-Wieland-Straße 4
D-89081 Ulm
www.liqui-moly.de
Amtsgericht Ulm HRB 1383 | Geschäftsführer: Ernst Prost
Court of registration Ulm, HRB 1383 | Managing Director: Ernst Prost
Unquote
Great. This is exactly what I wanted to hear. Thanks for the information.
Quick question, is the 5-6% replacing the oil or is it in addition to the the normal fill?
