So my power steering fluid is original...178k & 18 years old...now I will be changing the fluid soon.
Methods: 2 People will be used to insure the reservoir doesn't run dry.
1. Put the front on jack stands and turn the wheel side to side until clear fluid comes out while the engine is off.
or
2. Run the engine and just wait till the fluid comes out clear.
Which method would you guys recommend?
Also I was on rockauto.com and I realized there is a power steering filter for this car A-1 CARDONE Part # 20P038F? that one seem like it could or would fit, I do have cruise control which is right next to the power steering fluid reservoir where the return line is located. I hope these pictures work.
Let me know if I can install that filter or not.
or
