Originally Posted By: MONKEYMAN
Originally Posted By: mechanicx
Sounds like you're within specs, and good work. Hopefully now, your brakes will never develop pulsation and last until the pads have worn out. Then it'll be worth the extra steps. Keep us posted.
It has been a year. Today I installed a shim to correct for 0.006". The 0.003" one I initially installed just barely was getting me within specs and I have been hearing the passenger rotor making a noise when cold. It sounded like before I installed the shims when it was hitting a high spot each rotation at slow speeds. I recently installed new struts so maybe that had some impact on the noise? With the new shim it indexed at a little over 0.001. Brakes went a year/about 20,000 miles and worked good overall. Pads still have a lot of life left. I cleaned and lubed the guide and lock pins and cleaned and adjusted my rear brakes. I will test them out when I take my stepfather out to eat tomorrow. I want to wish everyone a Happy Fathers Day. I could not have done this without your help!
I still believe run out is the main cause of pulsation, or more precisely causes rotor thickness variation that causes pulsation. Pulsation caused by pad deposits induced thickness variation is not real for the most part IMO. Unless your rotors have corroded and the pads have cooked the lining off how could rotor deposits persist on a rotor that does not have run out? they wouldn't, They'd be ground flat during off brake driving and on braking.
When I get run out under .002, I never seem to run into pulsation rearing its head. This assume decent quality pads and rotors which you should always be using. If run out is above .002 or specs pulsation is almost certain to show up no matter what you do. Like clockwork due to run out induced thicknes variation.
Definitely clean the rotor and hub mounting interface. Clean the rotor mounting surface before having them machined.
If run out is above .003 with a machined or new rotor, the hub has way too much run out and really should be replaced instead of using a correction plate.
I'm a little confused if you have pulsation or run out problem again, or just brake noise. Brake noise and pulsation can be separate issues with separate causes.
*Important* when you shimmed the rotor again, did you machine or replace the rotor first and measure run out? Any rotor that's been ran with excessive run out, should be turned or replaced to correct thickness variation first. If the excess run out is corrected the rotor might eventually wear in even but you don't want to count on it.
