Juicers: anyone have one?
by car51
06/25/16 10:57 AM
Tips for cooling down a hot car
by mclasser
06/25/16 10:52 AM
Battery bit the dust
by aquariuscsm
06/25/16 09:58 AM
Walmart.com Chevron Supreme 5 quart in stock.
by BigD1
06/25/16 09:56 AM
Consensus on 12 month interval oil changes
by accobra66
06/25/16 09:11 AM
Truck Wars
by AirgunSavant
06/25/16 09:06 AM
A good read....The more things change....
by ryan2022
06/25/16 08:46 AM
Opinions on linksys 1900acs router
by madRiver
06/25/16 08:18 AM
Pick my oil change
by ram_man
06/25/16 08:09 AM
Weird!
by AirgunSavant
06/25/16 08:05 AM
Good Deed?
by AirgunSavant
06/25/16 08:02 AM
Vibration after rotating tires and painting wheels
by Drew99GT
06/25/16 08:02 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
82 registered (andyd, adolan21, 007, AirgunSavant, 901Memphis, aquariuscsm, 7 invisible), 2091 Guests and 11 Spiders online.
58257 Members
66 Forums
250781 Topics
#3346438 - 04/18/14 11:17 AM Carpet Cleaning Question
threeputtpar Offline
Loc: Appleton, WI
So my son set his breakfast on fire in the microwave this morning, and the house was filled with smoke for about half an hour. We opened all the windows (it's 35 degrees here today) to get the smoke out as fast as possible, but it still smells bad. I think that some of the smoke got in the carpeting in the dining room and bedrooms.
Any helpful DIY tips on what to do to get the smell out? Only thing I can think of is baking soda and a vacuum, but am hoping that there are other products that I can source that wouldn't require the assistance of a professional yet. I will call the professionals if I cannot remedy this on my own. Thanks.
2013 Honda Odyssey Touring Elite - M1 5W-20 / M1-101 40k miles
2008 Ford Taurus X - Resolute 5W-20 / MC FL-400S 128k miles
#3346444 - 04/18/14 11:21 AM Re: Carpet Cleaning Question [Re: threeputtpar]
dparm Offline
Loc: Chicago, IL
Give it time and lots of fresh air. If you are in a bind (i.e. hosting a party tomorrow or something), you'll need to get it professionally steam cleaned.
I would advise against baking soda and a vacuum. I tried something similar once and ended up accomplishing nothing other than spending two hours disassembling and cleaning the vacuum afterward.
2011 BMW M3 sedan ZCP
#3346452 - 04/18/14 11:26 AM Re: Carpet Cleaning Question [Re: threeputtpar]
Sam2000 Offline
Loc: Nevada
There are powders you sprinkle onto the carpet and vacuum up after a while.
Fabreze could work too.
#3346455 - 04/18/14 11:27 AM Re: Carpet Cleaning Question [Re: threeputtpar]
anonobomber Offline
Loc: WA
An ozone generator can help too. Make sure you get all pets and people out of the house for a while if you run one.
#3346458 - 04/18/14 11:28 AM Re: Carpet Cleaning Question [Re: threeputtpar]
SteveSRT8 Offline
Loc: Sunny Florida
Ozone is what pro fire damage restorers use, but it is toxic in high concentrations. Use with caution, sometimes available at rental places.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3346486 - 04/18/14 11:55 AM Re: Carpet Cleaning Question [Re: threeputtpar]
Quest Offline
Loc: beaver land EH?
+Steve's said.
Ozone is powerful and quick means of removing smoke/smell from house, but with serious side-effects:
human/pet health: high concentrations of O3 inhaled will damage your cells inside your lung, causing serious, if not fatal damage.
Also: because of it's high oxidation properties (oxidise on contact), it will also damage a lot of things in the house: i.e. if you have foam surround speak edge, the foam edge will decompose....certain plastics will become permanently damage as the plasticisers that hold/bond the plastic molecules together becomes oxidised due to O3 presence.
If it's just the carpet smells that you are trying to get rid of, try doing a light wet-carpet cleaning (with carpet cleaning machine of course) using diluted carpet cleaning solutions (1/3 or 1/4 the factory recommended mix) and then go from there.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3346489 - 04/18/14 11:58 AM Re: Carpet Cleaning Question [Re: threeputtpar]
lawman1909 Offline
Loc: USA
Fabreze should work, and obviously the ol' tried and true baking soda method will also be good.
2014 Honda CR-V AWD LX
M1 0W-20 EP/Fram Ultra 7317
Bless all LEO's, Fire, EMS, and military personnel both active and retired. USA! USA!
#3346502 - 04/18/14 12:18 PM Re: Carpet Cleaning Question [Re: threeputtpar]
Miller88 Offline
Loc: Onondaga County
The more important question is ... What did he have and how long did he have it in there to have it catch on fire?
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3346514 - 04/18/14 12:43 PM Re: Carpet Cleaning Question [Re: threeputtpar]
gfh77665 Offline
Loc: Southeast Texas
I use a product called OdoBan.
http://www.odoban.com/
This stuff is amazing. Its probably 2X or 3X times more effective than Febreeze, IMO. Thats saying a lot because Febreeze is a very good product its self.
Get the concentrate, and spray with a 2 gallon pump sprayer.
#3346560 - 04/18/14 01:31 PM Re: Carpet Cleaning Question [Re: threeputtpar]
SteveSRT8 Offline
Loc: Sunny Florida
Masking products such as mentioned above are simply a cover up.
Ozone chemically DESTROYS odors by oxidizing them. The by product is oxygen. Don't waste your time trying to deodorize a carpet that is not thoroughly cleaned first...
#3346659 - 04/18/14 03:32 PM Re: Carpet Cleaning Question [Re: Miller88]
Loc: Appleton, WI
I knew someone would ask. He has the same thing for breakfast everyday - pancake wrapped sausage on a stick. Usually my wife is in the kitchen with him as he goes through the routine, but she was upstairs with the baby.
40 seconds is the normal time, but he hit an additional 0 on the end of that. He called the wife downstairs in time for her to arrive to hear the microwave ding and somehow she got it out of there and into the sink and hit it with the sprayer. She thought that 911 would be called when she first saw it.
I haven't seen the damages yet.
#3347291 - 04/19/14 09:15 AM Re: Carpet Cleaning Question [Re: threeputtpar]
Propflux01 Offline
Loc: Arkansastan
If it is just the carpet...FOLEX
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
