new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
Car's models of 1990 and now
by HTSS_TR
05/30/16 07:02 PM
Another dealer oil change story
by mclasser
05/30/16 06:36 PM
Diagnosing HEI ignition module and ignition system
by Fsharp
05/30/16 05:58 PM
Spark such way?
by yvon_la
05/30/16 05:48 PM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
99 registered (2015_PSD, 4WD, AZjeff, 69GTX, 74DartSport, 04SE, 7 invisible), 1569 Guests and 139 Spiders online.
58023 Members
66 Forums
249614 Topics
#3345709 - 04/17/14 03:40 PM Should this belt be replaced?
Rolomoto Offline
Loc: PA
The ribbbed side looks good but the smooth side is streaked, does it need to be replaced?
Thanks
pic of belt
Edited by Rolomoto (04/17/14 03:41 PM)
2011 Toyota Camry
2001 Toyota Echo
1995 Toyota Tercel
#3345714 - 04/17/14 03:46 PM Re: Should this belt be replaced? [Re: Rolomoto]
michaelluscher Offline
Loc: Tri States Little Italy
I would....
'06 Toyota Camry SE V6 3MZ-FE 51k
'01 Mercury Villager Estate VG33E 48k
'06 Ford Taurus SE Vulcan 48k
'13 Chrysler 300 3.6 Pentastar 45k
2012-2015
#3345721 - 04/17/14 03:55 PM Re: Should this belt be replaced? [Re: Rolomoto]
CHARLIEBRONSON21 Offline
Loc: MEMPHIS, TN
Belts are inexpensive quick fixes. I'd do it and have piece of mind.
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
#3345725 - 04/17/14 04:01 PM Re: Should this belt be replaced? [Re: Rolomoto]
KrisZ Offline
Loc: Toronto, Canada
The outside doesn't matter much, it's how the inside looks like that matters.
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#3345732 - 04/17/14 04:14 PM Re: Should this belt be replaced? [Re: CHARLIEBRONSON21]
dparm Offline
Loc: Chicago, IL
Exactly.
2011 BMW M3 sedan ZCP
#3345746 - 04/17/14 04:31 PM Re: Should this belt be replaced? [Re: Rolomoto]
Kool1 Offline
Loc: California
If the streak lines can be felt with your fingernail, I would replace the belt. If the lines are visual only and can't be felt with your fingernail, I would leave the belt alone.
#3345764 - 04/17/14 05:02 PM Re: Should this belt be replaced? [Re: CHARLIEBRONSON21]
jeepman3071 Offline
Loc: Storrs, Connecticut
This, and keep that one as a spare should you need it.
2000 Jeep Cherokee Sport 4.0L (163k) - Pennzoil HM 10w30, Napa Gold 1516, Magnefine trans filter
#3345799 - 04/17/14 05:37 PM Re: Should this belt be replaced? [Re: Rolomoto]
eljefino Online   content
Loc: ME
That's pretty weird. Do you have a rusty pulley or something else messing with it? Has it been sitting?
#3345857 - 04/17/14 07:12 PM Re: Should this belt be replaced? [Re: eljefino]
FetchFar Offline
Loc: Colorado
You could just wait til it starts squealing and slipping. Then you know you've got a little stretching. Most stretch first before actually breaking later. Its kind of like how brakes have a built-in squealer to warn you ahead of time.
'07 BMW 530xi N52 engine, E60 chassis, 255 hp
'11 Chevy Camaro LS, 3.6L V6, Zeta chassis, 312 hp
'40 Chevrolet Special Deluxe 2-Door Town Sedan
#3345858 - 04/17/14 07:13 PM Re: Should this belt be replaced? [Re: FetchFar]
FetchFar Offline
Loc: Colorado
Or just change it to be sure. After 100,000 miles, those things might need it.
#3345885 - 04/17/14 07:47 PM Re: Should this belt be replaced? [Re: Rolomoto]
clinebarger Offline
Loc: Fort Worth, Texas
Nothing wrong with that belt, The belt doesn't look that old anyway.
2001 Chevy Camaro 5.3L/4L65E, Former V6 car
2010 Toyota Corolla 2ZR-FE/Auto
#3345904 - 04/17/14 08:02 PM Re: Should this belt be replaced? [Re: clinebarger]
another Todd Offline
Loc: Southern CA
+1
2015 Ford F250 Diesel Crew Cab FX4
2005 Ford Focus ZX4
2007 Ford Focus ZX4
2005 Ford Escape
2006 Ford Escape
#3346048 - 04/17/14 10:09 PM Re: Should this belt be replaced? [Re: Rolomoto]
Rolomoto Offline
Loc: PA
Thanks for all the answers!
2011 Toyota Camry
2001 Toyota Echo
1995 Toyota Tercel
#3346299 - 04/18/14 09:11 AM Re: Should this belt be replaced? [Re: Rolomoto]
zzyzzx Online   content
Loc: Baltimore, Maryland, USA
How many miles are on that belt?
