Shuffle your feet!
by Stelth
5 minutes 49 seconds ago
BMW Hexhead gearbox oil? Redline shockproof?
by David_g
38 minutes 56 seconds ago
Meg's Ultimate vs Collinite 845/476s?
by MisterBen
Today at 10:17 AM
Why do factory filters get such a bad rep?
by MisterBen
Today at 10:09 AM
Strange oil filter experiance. I'm stumped.
by callbay
Today at 10:06 AM
WiFi Extenders
by GGorman04
Today at 09:54 AM
Need Help getting on track/ 07 Honda Pilot
by 07Piloteer
Today at 09:23 AM
Installing A Magnefine Filter
by -SyN-
Today at 09:22 AM
Delo 400 Bottles LH?
by AirgunSavant
Today at 09:14 AM
wheel bearing grease
by meborder
Today at 06:59 AM
My car audio build thread
by dan_erickson
Today at 06:08 AM
Pegasus PS737 Cut Open. Unknown Mileage / Oil
by Farmer
Today at 05:45 AM
RM53119, Ctanke, jractk, LatitudeDancer, AKN
58647 Registered Users
69 registered (another Todd, andrewp1998, AirgunSavant, -SyN-, AIRJAC3, A310, 5 invisible), 2149 Guests and 7 Spiders online.
58647 Members
66 Forums
252444 Topics
#3342296 - 04/14/14 10:23 AM Corrosion X
2008wrx Offline
Loc: CA
I intended to buy this to waterproof an electronic item's circuit board from water damage. Can someone share their experience? How does this thing work? Its forms a protection layer after dried off or...? Thanks
P.S I am thinking to use plastic dip as well..
#3342356 - 04/14/14 11:19 AM Re: Corrosion X [Re: 2008wrx]
gomes512 Offline
Loc: Chicago, IL
I use Corrosion X HD inside the fenders on my vehicles. Have not tried the normal variant though.
The HD stuff is a thick yellow viscous gel with the consistency and thickness of naval jelly. It has a very strong smell of lanolin, which I believe is the major component of the product.
Once sprayed, it creeps a good bit then settles in place after a minute. It's definitely persistent and does an excellent job blocking moisture.
Have you considered potting your item's circuit board instead? MG Chemicals has a thermally conductive compound that I've used on headlight ballasts.
#3342386 - 04/14/14 11:38 AM Re: Corrosion X [Re: 2008wrx]
2008wrx Offline
Loc: CA
I want to waterproof a radio control car electronic speed control (ESC). I guess Corrosion XHD is better.
#3342778 - 04/14/14 06:47 PM Re: Corrosion X [Re: 2008wrx]
jonny-b Offline
Loc: Norway
Corrosion XHD is better. If I were you, I would also take a look at www.polytrondirect.com and find Polytron PL.
It is really amazing in protecting electronic equipment.
It is extremely good in lubricating, as well.
But, as you know, it has to be experienced, to believe it.
It cost 16USD.
I use both products.
Edited by jonny-b (04/14/14 06:47 PM)
#3344564 - 04/16/14 01:29 PM Re: Corrosion X [Re: 2008wrx]
DSparks Offline
Loc: Texas
Good luck and dont forget the receiver and servos...
I do rc too....1/8 nitro and ebuggy and 1/10 2wd buggy off road.
#3414105 - 07/04/14 12:03 AM Re: Corrosion X [Re: 2008wrx]
Idahokid Offline
Loc: Northern Idaho
I work for kenworth and I see this product in a lot of shops.Its a blue,green can.It really works good so the de-icer they use on the roads around here don't eat up the wiring of tail lights and generally all over.It looks like carmel and almost as thick.lol.I see all kinds of tricks.
Don,t beleive everything you think.
1998 Expedition 5.4
1989 F150 4x4
FL820s
Motorcraft syn blend 5w20
#3554601 - 12/03/14 03:03 PM Re: Corrosion X [Re: 2008wrx]
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
I have both regular and HD. The regular is great for a coat that "soaks" into a circuit board of walkie talkie , lock, battery terminal etc. the regular leaves an oily coat that is very trustworthy in it's soak tendencies.
The HD could be more robust for a splash area. It is indeed like caramel almost. Great garage door lube, really good. The regular and HD are very different when sprayed. The HD is much more likely to collect dirt particles and could cause electronic heat retention. But that may not matter in the least depending upon where and why it is used.
Such a thing as a 15k oil change or a lifetime transmission fluid!!??
#3555840 - 12/04/14 03:55 PM Re: Corrosion X [Re: 2008wrx]
Da Game Offline
Loc: Chicago
Anyone tried TC-11???
