Hard starting LCT snow engine..
by JTK
4 minutes 21 seconds ago
low-temperature oil gelling reversible?
by DrRoughneck
Today at 12:51 PM
I HAD to do it!
by Kuato
Today at 12:24 PM
Why Erin Esurance vanished from TV
by Benzadmiral
Today at 11:39 AM
Engine Light Advice
by coopns
Today at 11:14 AM
Caution UOA - PP 10W30 6881m on 2001 Jeep 4.0
by Donald
Today at 11:09 AM
What happened to the thin oil movement?
by camrydriver111
Today at 10:57 AM
Mastercraft Strategy tires (I'm cheap)
by Bgallagher
Today at 10:41 AM
Mobil Delvac ATF in a regular car transmission
by SuperValue
Today at 10:35 AM
Dumped the smartphone!
by andrewg
Today at 10:27 AM
Need to replace plugs - cooper,Iridium, or Plat?
by MoreCowbellAz
Today at 10:25 AM
Child bicycle trailer?
by Quattro Pete
Today at 09:19 AM
RTS, jhmed80, engus, Rob_Pol, Nick24w
56901 Registered Users
115 registered (05LGTLtd, 19kj57, akela, 87sammy, Al, 99TLC, 11 invisible), 1782 Guests and 199 Spiders online.
56901 Members
66 Forums
244602 Topics
Page 1 of 2 1 2 >
#3336912 - 04/08/14 02:43 PM is Rotella T5 10w-30 ok for wet clutch bikes?
kmrcstintn Offline
Loc: Palmyra, PA
a friend of mine is looking at a new bike (???Honda???) & was told it needs 10w-30 oil; he's asking about options for 10w-30 in the bike, which I believe is is a common sump design; before I recommend Rotella T5 10w-30 (haven't seen 'energy conserving' or 'resource conserving' in the API seal) I want to be sure it won't cause clutch slippage...
is Shell Rotella T5 10w-30 hdeo considered 'energy conserving' or 'resource conserving'? in other words, is it ok for use in a common sump bike? thanks
2015 Jeep Patriot Sport (2.4L 4-cyl), 2009 Suzuki GZ250 (249cc air-cooled single cylinder), 2006 Honda Shadow Aero 750 (745cc liquid-cooled v twin)
#3336917 - 04/08/14 02:59 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
Quattro Pete Offline
Loc: Great Lakes
Its technical data sheet says "Energy Saving", but that does not necessarily mean that it's loaded with friction modifiers.
The same text shows in TDS for Rotella T6 5w-40, which we know is fine for wet clutches.
Does his owners manual require that he uses JASO MA/MA2 approved oil? If so, for warranty purposes, he should probably stick with one that does. And if no, then he can probably run any 10w-30 oil out there.
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#3336919 - 04/08/14 03:00 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
Bebop367 Offline
Loc: Louisiana
T5 10w-30 appears to meet JASO DH-2 per spec. sheet below:
http://theoilnet.com/Atlantic-States-Lub...10W30-10W40.pdf
#3336927 - 04/08/14 03:09 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: Bebop367]
Bebop367 Offline
Loc: Louisiana
kmrcstintn
I messed up....misread.....
JASO DH-2 is regarding diesel engines....NOT Wet Clutches....
#3336938 - 04/08/14 03:23 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
rraiderr Offline
Loc: Dante's Inferno
What Honda runs 10W-30?
2015 GSX-R1000
2015 RMZ-450
2013 DRZ-400SM
#3336950 - 04/08/14 03:46 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
Loc: Great Lakes
Some of the new Honda bikes require this:
Quote:
API Service Classification SG or higher,
excluding oils marked as “Energy Conserving,”
SAE 10W-30, JASO T 903 standard MA
Then again, even Honda's own 10w-30 motorcycle oil doesn't list JASO MA compliance, to my knowledge.
#3336963 - 04/08/14 04:00 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: rraiderr]
steveh Offline
Loc: wisconsin
Even my 1985 Honda V65 says you can use 10W30 for under 90F.
#3336973 - 04/08/14 04:20 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: rraiderr]
Hirev Offline
Loc: Oregon
My 2013 CRF250L only list 10w 30 in the owners manual.
2006 Toyota Tundra, 2007 Corvette, 2009 Scion TC,
2001 KTM 380EXC, 2005 Yamaha FZ1, 2006 Honda 919, 2013 Honda CRF250L, 2013 Yamaha FZ6R
#3336982 - 04/08/14 04:32 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
kmrcstintn Offline
Loc: Palmyra, PA
didn't think about the 'warranty' aspect...I'll just say it's best to ask the dealer and a few independent shops (that service metric bikes) for suggestions
#3337014 - 04/08/14 05:19 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
JB426 Offline
Loc: NM, USA
Yes I think Honda is going to 10w30 on a lot of their bikes. Goldwings too I think. I just started the thread about the Honda Grom 125 and it only lists 10w30. The Pro Honda HP4S oil is only available in 10w30 as well.
#3337032 - 04/08/14 05:41 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
Chris142 Offline
Loc: apple valley, ca
I have been riding since 1977 and I have used every oil available. None have ever given me any clutch issues. IMO the Moly and slipping clutch thing rates right next to Pennzoil making sludge.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3337215 - 04/08/14 08:42 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: JB426]
Mackelroy Offline
Loc: Florida /Texas
Yeah Honda has been converting all of its recommends to 10w30 on its bikes, even bikes that used to quote 20w50 use. 20w50 isn't even in the manual of the same bike in a never changed motor. They started converting manuals to 10w30 around 2007.
#3337803 - 04/09/14 01:29 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: Mackelroy]
kmrcstintn Offline
Loc: Palmyra, PA
then Honda needs to seriously think about packaging and marketing a 10w-30 conventional oil!!! only having an expensive synthetic 10w-30 without a conventional alternative is not prudent...not everyone who buys a Honda is gonna want to buy the expensive Honda branded stuff; I'd be researching VOA's & PDS's and taking my chances with 10w-30 conventional PCMO's with little or no moly (Valvoline, Castrol, NAPA, and various house brands bottled by WPP/WNE like SuperTech, AutoZone, Advanced Auto Parts, etc) using 3000 mile OCI's; paying $12-15 per quart of oil is simply insane!!!
thankfully my 2006 Shadow still calls for 10w-40 which gives me many options amongst the realm of conventional, synthetic-blend, and full synthetic oils that are JASO-MA rated/certified...
Edited by kmrcstintn (04/09/14 01:40 PM)
#3337905 - 04/09/14 04:06 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
Loc: Great Lakes
They do: Honda GN4 10w-30 Motorcycle oil.
However, the recommended oil change interval on many of these new Honda bikes is 8,000 miles. You probably don't want to use mineral oil for such long intervals. Plus, Honda's mineral oil can cost as much as other manufacturers' synthetic. smile
#3338087 - 04/09/14 07:36 PM Re: is Rotella T5 10w-30 ok for wet clutch bikes? [Re: kmrcstintn]
dernp Offline
Loc: S/W Ontario, Estero, Fla.
To the OP your friend would be well served using Rotella T6 5w40.
2014 Honda Civic 1.8 28k TGMO 0w20
2013 Honda CR-V 2.4 AWD 48k TGMO 0w20
2012 Elantra 61k PPPP 5w20
2011 Tundra 5.7L 48K PP 5w20
Page 1 of 2 1 2 >
