Considering a new Lexus ES - Durability?
by David_Corbett
05/04/16 04:02 PM
2016 Audi S4 Factory Fill UOA at 3,793 Miles
by CrazyJeeper
05/04/16 03:25 PM
epoxy to secure asphalt shingle?
by Digital2k2
05/04/16 03:21 PM
$75 Seized engine
by demarpaint
05/04/16 03:19 PM
Question on a VIN number..
by dblshock
05/04/16 03:18 PM
Hydrogen Fuel Cell Vehicles
by HTSS_TR
05/04/16 03:18 PM
Wiper insert spring steel
by SHOZ
05/04/16 01:52 PM
BMW X1 / N20 2.0L Turbo - what oil ?
by Ndx
05/04/16 12:02 PM
1999 RANGER 3.0 SYNTHETIC OIL SUGGESTIONS
by AUTOTECH89
05/04/16 10:56 AM
Oil spec questions
by IllinoisSparky
05/04/16 10:43 AM
Amazing Rendition of the U.S. National Anthem
by MolaKule
05/04/16 10:37 AM
So many detailing products........
by buster
05/04/16 10:00 AM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
93 registered (aquariuscsm, 06AllAmerican, Al, Astro14, 69GTX, 10 invisible), 1 Guest and 0 Spiders online.
57794 Members
66 Forums
248463 Topics
#3320816 - 03/23/14 12:15 PM Help with 1 wheel out of Alignment
tnt31 Offline
Loc: TN
Craftsman 917.289272 (YTS4000)
Not sure how it happened as it is not my mower but one wheel is way out of alignment. (PIC Below) I have looked at it and do not see anything obviously bent and would like some opinions from some who are probably more experienced than I am before I just go removing parts. From looking at the parts diagram it looks like the left spindle and/or drag link would be the likely suspects. If so is there a way to check without removal and if so is there a way to repair or will they need replacing? I am thinking the left as this is the way the wheels look when the steering wheel is at the straight position. If I turn it so the left wheel is straight then the right wheel is way out and the steering wheel looks like your attempting to turn.
Thanks in advance
#3320821 - 03/23/14 12:24 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
eljefino Offline
Loc: ME
Seems your left kingpin is an inch left of center.
#3320822 - 03/23/14 12:25 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
Donald Offline
Loc: Upstate NY
Its got to be something bent or loose. Can you have someone hold the steering wheel while you try and turn the wheel to be straight?
Its a 917 model so a Husqvarna.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3320915 - 03/23/14 02:11 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
Eddie Offline
Loc: Florida, Cape Coral
Appears the front axle with spindle is bent backwards. Steering rod will also be bent. Something hit hard with the left front wheel. Ed
Edited by Eddie (03/23/14 02:12 PM)
CX5 Touring 2.5L :-)
#3321036 - 03/23/14 03:59 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
PhilsSmallEngine Offline
Loc: Philadelphia area, PA
Doesn't that main axle look bent? I can't tell, but it looks like it is from that picture when you look at the angle of the spindle and drag link along with the gap in the mower deck on the floor. There is also a potential that the gear sector holes are bent or broken too. Since the drag link is tied there, those are the first two I would check after verifying the axle and spindle aren't bent.
Get the wheels up in the air and see how much play is in the wheel. That should help you determine how far the steering is damaged.
Someone smacked a curb really hard.
92 Hechinger Mower, 98/02 Lawnboy Duraforce modded, 76 Ariens Tiller, 8? Kemp Chipper, 91 Homelite Trimmer, 90 Redmax CHT230, out w/new, in w/old!
#3321081 - 03/23/14 04:49 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
tnt31 Offline
Loc: TN
Thanks to all who have replied. I probably will not get to go over to where it is at and look at it until Saturday. The more I look at the PIC the more it looks like the axel to me also. I thought I looked at it closely the other day but obviously not close enough.
#3321384 - 03/23/14 09:10 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
cronk Offline
Loc: Watertown, New York
Is that a stamped steel axle or cast iron? My friend had a Craftsman with a stamped front axle, and it was really flimsy. It bent a few times from hitting a rut or small hole. He tried straightening it and welding reinforcements on it but it just kept bending. The only long term fix would be swapping a cast iron axle in, much stronger. He also had other issues with the sector gears in it, they wore and kept jumping.
1998 GMC C1500
1999 Saturn SL2
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
#3321449 - 03/23/14 09:56 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
Joe_Power Offline
Loc: USA - Coast to Coast, Border t...
Loose nut behind the wheel
2011 Jeep Wrangler
2015 Chevrolet 2500HD LTZ
2011 Harley Davidson FLHX
Common sense is a flower that doesn't bloom in everybody's garden.
#3322210 - 03/24/14 04:06 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
lars11 Offline
Loc: Sweden
yeah, how can you be sure it's not the other three that's out?
wink
#3327387 - 03/29/14 02:23 PM Re: Help with 1 wheel out of Alignment [Re: tnt31]
tnt31 Offline
Loc: TN
Got to check it out closer today. It appears to be the LH wheel spindle assembly. Looks like I can get a new one for about $40.
