Is Legalizing Marijuana Safe????
by qwerty1234
05/30/16 03:44 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
18 registered (bubbatime, bernau, ASW338, asand1, 2 invisible), 534 Guests and 316 Spiders online.
58019 Members
66 Forums
249584 Topics
#3312352 - 03/14/14 11:23 PM Crankshaft Design
MolaKule Offline
Loc: Iowegia - USA
"You are free to choose, but you are not free from the Consequences of your choice." Dr. Laura. smile
#3312367 - 03/14/14 11:59 PM Re: Crankshaft Design [Re: MolaKule]
Shannow Offline
Loc: Oz
That's a lot of information in a small space, thanks.
#3312379 - 03/15/14 12:22 AM Re: Crankshaft Design [Re: MolaKule]
expat Offline
Loc: Canada
Thanks for posting.
But to put things in perspective:
Austin Seven two bearing crankshaft:
http://www.a7c.co.uk/parts/BB1photo.jpg
Amazingly they will run 6k rpm
#3312388 - 03/15/14 12:37 AM Re: Crankshaft Design [Re: MolaKule]
edhackett Offline
Loc: Sequim, WA
Here's Alfa Romeo's take on a 4 cylinder crank from the mid 50's through the end of production of the Alfa designed engines.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
#3312418 - 03/15/14 01:46 AM Re: Crankshaft Design [Re: MolaKule]
Shannow Offline
Loc: Oz
Quote:
There were some initial problems with bolt-on counterweights, which resulted (as one Formula One designer told me) in "several deep holes being dug in the surface of a few racetracks". There are tensile and fatigue stress issues, as well as the inevitable fretting between contact surfaces and the requirement for highly developed fastener technology.
Having observed more than a couple of high cycle fatigue failures of turbine blades, with horizontal shaft rotating equipment, there is obviously a 2g difference in the centripetal acceleration at 12:00 versus 6:00.
Most of the genuine high cycle fatigue (calc'd at 170x10^6 cycles from crack to failure in most) ones that I've seen have ultimately failed at around 6:00, as evidenced by trajectories and consequential damage.
