Originally Posted By: Jarlaxle
Did it have cruise control?
Yes it did...
Hmm...Sonic for ~1200 mile road trip, yes or no?
Get a Cruze if wanting to stay with GM. Unless you need the footprint of the Sonic, the quieter and more grown-up Cruze will do just about everything better.
For the coolant issue, it's not as prevalent as CruzeTalk makes it out to be. A few folks had crummy experiences and posted a lot about it. There are several documented fixes that work to eliminate the smell. The easiest one is to siphon off some coolant from the surge tank until the tank is halfway full. If there is a coolant smell in the cabin with the heater on for a 2011-2012 Cruze, that's a grease in the HVAC system outgassing. GM fail on that one.
If a 1.4T powered Chevy is losing coolant, start with the thermostat and the water pump. Water pumps are known to fail randomly on 2011-2013 cars, and will be replaced with an updated one under powertrain warranty. If there's a coolant smell after replacing the water pump, lower the level in the surge tank to get the smell to disappear. Thermostats affect a much smaller subset of cars.
