This is on the MG. That has a plumbing nightmare of hoses going between the water pump, thermostat housing, expansion tank, intake manifold, automatic choke on the carburetor, heater valve, and the heater core. Trouble is, even with the original hoses, there are cases where the hose fits perfectly on one end, but the other end goes to a much smaller nipple and has a hose clamp cranked way down to squeeze it and hope it doesn't leak. They do leak.
Short of building some adapter using different hose fittings to go between two different hose sizes, is there a nice way of fitting these hoses?
