Buying services for new vehicles?
by powayroger
11 minutes 51 seconds ago
Hard to find QSUD 0w20
by chiefsfan1
57 minutes 46 seconds ago
Small compressor advice + a story of stupidity
by dishdude
Today at 04:33 PM
w116 300sd Lower shock bolt type/size
by Gito
Today at 04:20 PM
FRAM XG7317 Cut Open
by HX520W
Today at 04:17 PM
weld leaking on transmission pan.
by motor_oil_madman
Today at 03:41 PM
PP and Honda CR-V
by klt1986
Today at 03:04 PM
113,800 miles on plugs w/ pics - 2009 F150 5.4 3V
by 04SE
Today at 02:59 PM
Sludged 1zz-fe pic... Ex-fleet car.
by SanProsan
Today at 02:53 PM
Autozone oil score today
by jdavis
Today at 01:12 PM
Valvoline V0-88, 5,000 miles, CUT OPEN
by car51
Today at 12:27 PM
Timken throwout bearings?
by buck91
Today at 12:17 PM
Compignite, pezman65, Wansu, DaleAZ, Nazmorgul
56846 Registered Users
83 registered (amusing, Al, 1foxracing, 440Magnum, 13Track38, 1989outlaw, 1 invisible), 1168 Guests and 202 Spiders online.
56846 Members
66 Forums
244380 Topics
#3286359 - 02/18/14 03:59 PM replaced raidiator...still smell coolant..no leaks
Mark72 Offline
Loc: Illinois
I guess the subject speaks for itself. I own a 2001 Nissan Sentra 2.0. Had a new radiator put in it 3 weeks ago. No leaks, all clamps are working and no moisture around any of the hoses but when I shut the car off after a drive I still smell coolant on the outside of the car. When I open the hood, it confirms it because that is definitely what Iím smelling but nothings leaking and I donít know what to do. Any ideas? Would it take 3 weeks for residual to burn off?
#3286369 - 02/18/14 04:07 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Drew99GT Offline
Loc: Colorado Springs
Coolant can stick around and stink for a while. If your Sentra has splash shields underneath, it can puddle up and take a while for the water component to evaporate and /or for the coolant to get splashed out of any crevices/nooks/crannies from driving. As long as the level stays normal and no visible coolant is leaking, you should be good to go.
Edited by Drew99GT (02/18/14 04:07 PM)
#3286373 - 02/18/14 04:10 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Mark72 Offline
Loc: Illinois
Well that was my thought to..but Iíve had the car on several highway trips since the radiator was replaced 3 weeks ago. Would that not have burn it off by now?
#3286374 - 02/18/14 04:12 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Have you checked the coolant level? If it's low it may be a bad Intake Manifold Gasket.
#3286381 - 02/18/14 04:17 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Warstud]
Mark72 Offline
Loc: Illinois
Thought of that too...so I been checking the oil and it looks fine...no discoloration at all.
#3286467 - 02/18/14 05:27 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
Warstud Offline
Loc: MIchigan
Did you smell coolant prior to replacing the rad? And why did you replace the rad?
#3286505 - 02/18/14 06:01 PM Re: replaced raidiator...still smell coolant..no leaks [Re: Mark72]
MolaKule Offline
Loc: Iowegia - USA
Take off the shields and go to a manual car wash and spray the engine compartment with soap and rinse thoroughly.
Let it dry and check for any new coolant leaks.
Sometimes the hose clamps need re-tightening or replacement.
I have this condition that keeps me from going on a diet. It is called, "an appetite." smile
