mixing gear oil for manual tran
by ntoxicator
06/28/16 11:04 AM
Transmission shudder/and an honest mechanic
by gman2304
06/28/16 10:57 AM
M1 0w40, 13,011 miles, 2010 BMW 328i
by Patman
06/28/16 10:32 AM
VW to pay owners up to $10K...
by Quattro Pete
06/28/16 10:19 AM
Lawnmower Won't Start When Engine Hot
by jkon
06/28/16 10:09 AM
Rheology of Viscosity Modifiers and ULV Lubricants
by Solarent
06/28/16 10:09 AM
Block heater leaks, Use sealant on expansion plug?
by Colt45ws
06/28/16 10:02 AM
85 octane... Wth?
by horse123
06/28/16 09:39 AM
Fram XG2 Bypass Valve
by Canadastang
06/28/16 09:22 AM
'02 VW Cabrio -- Pros & cons?
by Benzadmiral
06/28/16 08:27 AM
Early review on 2015 Chrysler T&C
by badtlc
06/28/16 07:25 AM
New car storage
by JoelB
06/28/16 07:17 AM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
96 registered (adamrc, Alfred_B, AirgunSavant, b1amgm47, Bandito440, ARCOgraphite, 9 invisible), 1974 Guests and 13 Spiders online.
58295 Members
66 Forums
250930 Topics
#3274511 - 02/08/14 07:16 AM Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax
DNVDMAX Offline
Loc: Alaska
Very pleased with these results.
Lab was ALS-Atlanta this time, I bought the NAPA $14 kit, and the universal averages are from my first Blackstone report.
I have to admit I got the OCI itch to dump it at 15k, but I could DNewton's voice in my head, "Don't do it," "that's wasteful." Thanks Dave.
I will probably just keep my OCI at 20k and sample for a health report.
I kept the "mild" EFI Live tune throughout the duration of this OCI. I also changed the Baldwin Oil filter @10k into the OCI and cleaned the AFE 7-layer air filter ~500mi into the OCI.
The .5 qt of makeup is due the filter change.
BTW, my wife and I still drive it like it's stolen, and it's saw plenty of short trips under 5mi.
Comments appreciated.
Code:
MI/HR on Oil			21,466			13,893			6,700
MI/HR on Unit			106671			85,205
Sample Date			01/13/14		03/05/12
Oil				Rotella T6 5w-40	Rotella T6 5w-40
Make Up Oil Added		.5 qts (Filter)		0 qts			Univ Averages
ALUMINUM			6			6			2
CHROMIUM			<1			1			0
IRON				24			34			13
COPPER				4			14			13
LEAD				1			0			3
TIN				2			3			1
MOLYBDENUM			67			62			36
NICKEL				<1			0			0
MANGANESE			Not Tested		1			0
SILVER				<1			0			0
TITANIUM			<1			0			0
POTASSIUM			<5			7			4
BORON				23			38			89
SILICON				6			8			10
SODIUM				10			4			4
CALCIUM				860			970			2212
MAGNESIUM			1171			1258			376
PHOSPHORUS			1070			1098			1082
ZINC				1312			1309			1268
BARIUM				<1			0			0
										Should Be:
SUS Viscosity @ 210F		Not Tested		77.3			66-78
cSt Viscosity @ 100C		15.0			14.84			11.9-15.3
Flashpoint in F		Not Tested		420			>410
Fuel %				<1			<0.5			<2.0
Antifreeze %			No			0.0			0.0
Water %				0.07			0.0			<0.1
Insolubles %			0.3			0.1			<0.8
TBN				7.2			8.3			>1.0
06 GMC 2500HD DMAX EFILIVE M1 TDT 5w-40 K&N
12 VERSA SEDAN M1 EP 5w-20 Purolator P1
91 GMC K1500 5.7L Maxlife 10w-40 WIX
#3274519 - 02/08/14 07:34 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
01_celica_gt Offline
Loc: St. Louis, MO
Code:
ALUMINUM			6			6			2
CHROMIUM			<1			1			0
IRON				24			34			13
COPPER				4			14			13
LEAD				1			0			3
TIN				2			3			1
MOLYBDENUM			67			62			36
NICKEL				<1			0			0
SILVER				<1			0			0
TITANIUM			<1			0			0
POTASSIUM			<5			7			4
BORON				23			38			89
SILICON				6			8			10
SODIUM				10			4			4
ZINC				1312			1309			1268
BARIUM				<1			0			0
										Should Be:
Fuel %				<1			<0.5			<2.0
TBN				7.2			8.3			>1.0
WOW TBN of 7.2, couldn't you go significantly further?
Red/Black 01 Celica GT 1ZZ-FED(Rebuilt @ 211/144) @ 211/145k
Red 02 Corolla S 1ZZ-FED(Rebuilt @ 140k) @ 141k
All Autos!
#3274528 - 02/08/14 07:41 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
LotI Offline
Loc: America's Dairyland
Stellar TBN retention. Are we starting to see some thickening? I show virgin vis. At 14.2.
I am seeing that people who drive hard show great UOA's. Hmmm
03 Honda VFR800VTEC .8L RT6
04 Kawasaki Vulcan Nomad 1.5L RT6
12 Ford E450 6.8L RP
14 Honda Accord Sport 2.4L PPPP
The biggest is the slowest.
#3274605 - 02/08/14 09:01 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
DNVDMAX Offline
Loc: Alaska
Yeah I think although the TBN is great the thickening does raise an eyebrow. Even the sample seemed a little thick at room temp.
My EGR is disabled, but my PCV is intact.
Here is the UOA doc:
#3274634 - 02/08/14 09:38 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
abycat Offline
Loc: grande prairie AB
I bet 30k would look pretty close to what you have there. I wonder if it would be progressively thicker as km goes on. Those dmax are really nice on oil.
2004 f350 6.0
2011 nissan versa hb
#3274668 - 02/08/14 10:02 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: abycat]
Loc: St. Louis, MO
That UOA is in miles
All Autos!
#3276124 - 02/09/14 04:21 PM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
dustyroads Offline
Loc: upstate NY
Would've been interesting to see TAN but everything looks excellent. It appears that you could go longer still if you wanted to, but do what you're comfortable with based on the info you now have.
I can't help but think even a conventional could get you 20k based on the dmax historical results. Then again maybe it would thicken much more than the t6 (?)
Edited by dustyroads (02/09/14 04:32 PM)
2011 Taurus sel
QSGB 5W20 MC FL500S
#3276294 - 02/09/14 07:45 PM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
dnewton3 Offline
Loc: Indianapolis, IN
Typical boring Dmax UOA. Nothing to be afraid of there; looks great. Air filter is doing great with the Si so low! Don't change it; it's doing exactly what you need it to do.
Perhaps consider getting a Fumoto valve; then you can sample first, and then only decide to change oil if the UOA indicates (which this would not). That is what I'm doing on mine; into my third year of the OCI. You might also consider a bypass system, if you drive far annually. Then you can really stretch the OCI!
Edited by dnewton3 (02/09/14 07:46 PM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3279066 - 02/12/14 08:27 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
A_Harman Offline
Loc: Michigan
Here is one of my oil analysis reports on RT6 in a Cummins at 24k miles:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3192153/01_Cummins_Dodge_Ram_2500,_243#Post3192153
Fairly similar numbers. TBN holds up well.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3279950 - 02/12/14 08:01 PM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: A_Harman]
DNVDMAX Offline
Loc: Alaska
A_Harman,
Wow, those numbers are pretty close. I even run similar boost levels at 35 psi.
I wonder how Mobil 1 TDT would compare. I bought a good stash when AZ was running their 12.99 special. I just hate to stray from something that is working fine.
I like the idea of putting a bypass on the truck, as DN3 stated above, but I don't know how much of an ROI I will see.
Off subject: Man do I miss my 2002 Z/28 like the one listed in your sig. I bought one from the Texas Department of Public Safety in 2003 with 2,100 miles on it. It had roll up windows, manual locks, and a radio with no CD player. I was able to get into the deep 11s for not much cash, I sold it in 2006. I liked the camaro more than the 2002 WS6 T/A that replaced it.
#3281867 - 02/14/14 11:45 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
Black6spdZ Offline
Loc: MS
I bought my 07 with 20k on it and my first two oil changes filled it with M1 TDT, UOA at ~10k miles, copper was VERY high. Something in the M1 TDT leaches the copper from the oil cooler. Then I switched to T6 and it went back to normal.
#3282619 - 02/15/14 04:50 AM Re: Shell RT6, 5w-40, 21,466mi, 06 GMC Duramax [Re: DNVDMAX]
dnewton3 Offline
Not just TDT. Amsoil and RP and RL have been known to do it as well. It's also happened with "normal" products, but at a much lower lever and frequency.
It's not harmful to the engine at all. But it has the ability to mask the onset of real problems, and by the time the overt spike of Cu from the chelation settles, the other problem may be a much bigger issue.
Look at the data in my "normalcy" article. Then consider what happens when we try to discover engine issues ...
If your Dmax were to average 3ppm over 7k miles, and you changed to a fluid that suddenly spike your Cu to 150ppm, you'd NEVER see any true shift in actual wear during that period. If it takes perhaps three successive OCIs to "flush" out the chelation from the reaction, and you try to get reasonable use of the syn fluid (perhaps 25k miles per OCI), then that represents 75k miles of driving around where you cannot see the trending due to wear in Cu.
Typically, we are looking for wear trending (three successive moves in the same direction in or out of range) to indicate an issue. Knowing the standard deviation helps here to understand what is "normal" for variance. Presume 3ppm in sigma allowance for an example.
So if you typically run 3ppm of Cu, and you start to get wear that shows 9 additional ppm of Cu, that would be a total of 12ppm of Cu in a "normal" OCI. We'd notice that for sure. But if you were at 120ppm of Cu due to the chelation, and you "add" in 9ppm of Cu wear, you'll never know it! It's too flipping hard to discern small wear shift from BIG chemical noise. How high can this get? I have documented data from one Dmax UOA where the Cu spiked to over 900ppm in the OCI. Yes - OVER NINE HUNDRED PPM! That is the most extreme case, but it's not uncommon to see 100-200ppm in an OCI often with this reaction.
Many folks would note that you can look for Pb to increase and if it's not there, to ignore the Cu spike. DANGEROUS! That is making a WHOLE lot of presumptions that cannot be thrown out like a blanket. Here are things to consider:
1) Pb avg (both macro and micro)
2) Pb std dev (macro and micro)
3) Engine family history
4) Engine family design (is Pb always present in the component design?)
5) External contributors to Pb?
I would agree that watching Pb is a good idea, but you cannot safely rely on it as a 100% effective communicative device to say you can simply ingore Cu. There are many times when Cu wear may be present, and no Pb shift takes place. They are not 100% mutually inclusive; they can be exclusive depending upon many other conditions.
These chemical Cu reactions are not harmful at all, but they completely mask part of the information we're seeking by doing a UOA in the first place.
I am not saying that one should never use those products. Nor am I saying that one should quit doing UOAs if you choose to use them. I am stating that you must understand all the benefits and limitations of every product you use, and that it's not just about the lube, but also the equipment and monitoring processes you select as well.
Edited by dnewton3 (02/15/14 04:53 AM)
