In an earlier post, I asked for advice on using MTF in my Ion's tranny. I settled on using Pennzoil Synchromesh, as it's available pretty much everywhere for cheap and has great looking specs.
After draining the Dex/Merc and filling with the MTF, the improvement was instant - as in, I could tell it was better just moving the gear shift with the car not even running. A thorough test drive revealed no more notchy shifts or scary noises from the trans. In fact, the car was so quiet I came to realize that some noises I was afraid were coming from the engine (timing chain, so I thought) actually were coming from the trans.
The computer at AAP said to use Dex/Merc in this trans, and so did the Saturn forums I frequent. After unsatisfactory shifting for 20,000 miles with Dex/Merc, I called the service guy at my local Chevy dealer. He said Ions/Cobalts/G5s came from the factory filled with Dex-Synchromesh, not standard Dex ATF, and the synchromesh fluid is what anyone who came to the dealer for tranny service would get.
Given the instant and tremendous improvement I experienced, I believe him. If you have a manual tranny Ion/Cobalt/G5, use your favorite brand of synchromesh, not ATF!
Thanks to MolaKule for his posts on MTF vs. ATF in fwd trannies, plus the suggestion to go with the Pennzoil.
