There are at least two other threads on this topic.
Let's lock this one!
Third Discussion on this Topic
Quote:
Originally Posted By: MichaelDCRogers
Wonderful....
...How do Gas to liquids work...What are they so good at, on the molecular level, that allows them to semi-rival PAOs?
Background:
Quote:
5. Making GTL (gas to liquids) products
The plant creates a range of products from natural gas that would otherwise be produced from oil.
Using another Shell proprietary catalyst, the long hydrocarbon molecules from the GTL reactor are contacted with hydrogen and cut (cracked) into a range of smaller molecules of different length and shape. Distillation separates out the products with different boiling points.
GTL PRODUCTS:
GTL Naphtha is used as a chemical feedstock for plastics manufacture.
GTL Kerosene can be blended with conventional Jet Fuel (up to 50%) for use in aviation – known as GTL Jet Fuel – or used as a home heating fuel.
GTL Normal paraffins are used for making more cost-effective detergents.
GTL Gasoil is a diesel-type fuel that can be blended into the global diesel supply pool.
GTL Base oils are used to make high-quality lubricants.
Source:
Shell GTL
The Process:
GTL Process
Edited by MolaKule (02/03/14 06:06 PM)
