What is this plant?
by skyactiv
07/24/16 11:16 AM
Recycling
by mjoekingz28
07/24/16 10:30 AM
Craftsman Action Bypass Lopper ~$11.70
by Sayjac
07/24/16 09:51 AM
2017 Fusion Hybrid
by AirgunSavant
07/24/16 09:50 AM
Grease that's universal on ALL aspects of car care
by NattyBoh
07/24/16 09:45 AM
Oil made from natural gas?
by Sealbilly
07/24/16 09:18 AM
Rotella line upgraded
by Sealbilly
07/24/16 09:13 AM
Kendall VersaTrans LV for Toyota WS?
by Slick17601
07/24/16 08:03 AM
Clutch problem
by chrisri
07/24/16 07:49 AM
Peppers: do you grow them?
by car51
07/24/16 07:29 AM
Havoline conventional $2.99 at Rural King
by car51
07/24/16 06:35 AM
killing weeds without poisoning well
by oilboy123
07/24/16 01:27 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
86 registered (4WD, andyd, Al, AandPDan, alanwayne1908, aquariuscsm, 7 invisible), 2037 Guests and 14 Spiders online.
58578 Members
66 Forums
252186 Topics
#3148811 - 10/08/13 06:03 AM need something to dissolve rust flecks on rawsteel
dwcopple Offline
Loc: Michigan
I have a machined piece of steel "in the white" that has some small rust flecks over it. I tried mineral spirits and 0000 steel wool and it just lightened it a bit. what should I use?
2015 Chevrolet Silverado All-Star edition 4.3 Ecotec3 V6
2011 Chrysler 200 Limited 3.6L V6
#3148814 - 10/08/13 06:08 AM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
Jay1981 Offline
Loc: Michigan
I've used vinegar to soak tools with rust on them. It works well but then they need a light coat of oil or they rust again.
Formerly "T4R"
2007 Chrysler T&C Touring, 98k
2010 Ford F-150 STX, 76k
#3148825 - 10/08/13 06:27 AM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
Phishin Offline
Loc: Indiana
Vinegar works well. And yes, oil or prime/paint immediately....acid will activate the metal to quickly rust again.
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#3148895 - 10/08/13 08:05 AM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
nitehawk55 Offline
Loc: Ontario , Canada
phosphoric acid
05 Ford Five Hundred AWD 3.0 DOHC V6 CVT tranny
#3148951 - 10/08/13 09:14 AM Re: need something to dissolve rust flecks on rawsteel [Re: nitehawk55]
SatinSilver Online   content
Loc: Ohio
2012 Toyota Camry 62k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 103k miles- MC 0w20 syn-blend, MC 822 filter
#3148953 - 10/08/13 09:18 AM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
JHZR2 Offline
Loc: New Jersey
Naval Jelly?
#3148961 - 10/08/13 09:26 AM Re: need something to dissolve rust flecks on rawsteel [Re: nitehawk55]
Phishin Offline
Loc: Indiana
Originally Posted By: nitehawk55
phosphoric acid
Regular Coca Cola.
#3148962 - 10/08/13 09:27 AM Re: need something to dissolve rust flecks on rawsteel [Re: JHZR2]
dparm Offline
Loc: Chicago, IL
Originally Posted By: JHZR2
Naval Jelly?
Bingo. You need to neutralize the rust, but you must paint over it immediately or the rust will just come back.
2011 BMW M3 sedan ZCP
#3148965 - 10/08/13 09:38 AM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
benjamming Offline
Loc: northern Alabama
Naval jelly has phosphoric acid - up to 30% along with a small amount of sulfuric acid (think pickling).
Are you experience flash rust on the part?
#3149378 - 10/08/13 03:42 PM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
dwcopple Offline
Loc: Michigan
used CLR and it darkened the metal significantly frown Now what?
#3149724 - 10/08/13 09:15 PM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
dwcopple Offline
Loc: Michigan
I wiped of the blackish residue and wiped it down with Ed's Red. I just took it out and dunked it in my used engine oil and am letting it drip dry back into the bucket overnight. Tomorrow I'll brush it off with some kerosene and a parts brush. Then it should be good to go I guess.
#3150001 - 10/09/13 08:57 AM Re: need something to dissolve rust flecks on rawsteel [Re: dwcopple]
Phishin Offline
Loc: Indiana
CLR created oxides on the metal. That's why it darkened up.
Why not degrease the part, and immediately slap some primer on it....and then put whatever paint/finish you want on it?
My favorite rust preventor is Phosphoric Acid with Zinc Oxide dissolved in it. I make my own. But POR 15 makes it as well. The acid eats away the rust, and the zinc deposits on the iron (which forms a galvanic-like coating on the steel). This prevents rusts from forming by "sealing" it off, and the zinc is sacrificial to the iron.
Then paint immediately once dry. POR15 has an excellent paint product as well.
#3150800 - 10/09/13 11:01 PM Re: need something to dissolve rust flecks on rawsteel [Re: Phishin]
wally6934 Offline
Loc: Wi
Can you share your top secret procedure for making the generic Por-15. Also does it have a shelf life.
#3150894 - 10/10/13 06:06 AM Re: need something to dissolve rust flecks on rawsteel [Re: Phishin]
dwcopple Offline
Loc: Michigan
because it is a moving part on a rifle
#3269660 - 02/03/14 09:40 PM Re: need something to dissolve rust flecks on rawsteel [Re: Phishin]
daves66nova Offline
Loc: los angeles
THIS SPACE FOR RENT, PLEASE PM ME.
