Please excuse my delay in responding to this post. I was in Florida for the 24 hours and decided to extend the stay a few days.
Originally Posted By: TheScaryOne
Originally Posted By: CapriRacer
1) Uneven wear is ALWAYS alignment. It is NEVER tires.
That's just not true. You even mention tire pressure further down your list.........
I think we have a difference in our definition of "Uneven Wear" This thread is about the wear being different on the inside vs outside - and that is what I am using for a definition.
Put another way, center wear (more wear in the center than at the shoulders) and shoulder wear (more wear at the shoulders than the center, but the wear is the same on both shoulders) are not being included in the term "Uneven Wear".
..... Lack of rotation, bad suspension components and defective tires can cause uneven wear too. This chart is about big trucks, but it applies to cars and pickups all the same......
First, lack of rotation doesn't cause uneven wear. It doesn't even cause shoulder wear or center wear. What it does is give those type4s of wear a chance to become more severe. Whatever the cause of a tire wear condition is, rotating tires slows down the rate at which these conditions appear by putting a different wear pattern on top of what the previous pattern was.
Second, bad suspension components can be the CAUSE of a bad alignment, but it is still alignment causing the wear.
And last, the chart doesn't mention defective tires at all, so your statement about defective tires is not supported.
(Concession: I will concede that some defects in tires cause uneven wear - BUT - those are so very rare, that for practical purposes, you can ignore defective tires as a cause and be correct 99.9% of the time.)
......FWD vehicles that don't rotate usually have worn shoulders on the front, and worn centers on the back.......
Yeah, but that's not quite true either. There's a lot going on and tire wear isn't easily characterized unless we start with the condition and work backwards.
Put another way, we can have a vehicle that is perfectly "In Spec" and still get uneven wear. We can also have a vehicle "Out of Spec" and get even wear. My experience is that "USUALLY" FWD cars evenly wear tires, if the tires are regularly rotated, and if not, then the rears tend to develop irregular wear.
The problem with the previous statement is that there are a ton of examples of FWD vehicles that don't follow that - to the point where the term "usually" is hard to apply.
So, PapaBear. I'll bet that wasn't as entertaining as you expected.
