Juicers: anyone have one?
by car51
2 minutes 57 seconds ago
Tips for cooling down a hot car
by mclasser
7 minutes 46 seconds ago
Battery bit the dust
by aquariuscsm
Today at 09:58 AM
Walmart.com Chevron Supreme 5 quart in stock.
by BigD1
Today at 09:56 AM
Consensus on 12 month interval oil changes
by accobra66
Today at 09:11 AM
Truck Wars
by AirgunSavant
Today at 09:06 AM
A good read....The more things change....
by ryan2022
Today at 08:46 AM
Opinions on linksys 1900acs router
by madRiver
Today at 08:18 AM
Pick my oil change
by ram_man
Today at 08:09 AM
Weird!
by AirgunSavant
Today at 08:05 AM
Good Deed?
by AirgunSavant
Today at 08:02 AM
Vibration after rotating tires and painting wheels
by Drew99GT
Today at 08:02 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
83 registered (007, AirgunSavant, 901Memphis, andyd, AnthemBassMan, 8 invisible), 2083 Guests and 11 Spiders online.
58257 Members
66 Forums
250781 Topics
Page 1 of 3 1 2 3 >
#3254058 - 01/20/14 01:43 PM PhoCo Box Clean-Up
sleddriver Offline
Loc: Central Texas
I've been using a temp piece of CAT5 from the router out the window to the PhoCo demarc-box as my cheap POTS 2-pair that's > 30+ years has aged so bad the insulation has broken down, causing shorts. It's not even suitable for the phone, much less ADSL.
Yesterday, I opened the box and noticed all the brass was very dull looking and there were signs of green corrosion in the threads. I began by removing all the wires, nuts, washers and spraying them with Cramolin Red (DeOxit) in a small container while I worked. I chucked a small wire-wheel brush into the moto-tool and used it to clean the threads and everything else until it was shiny brass again. Then applied Cramolin Blue (PreserveIt) before reassembly.
I also wanted to run a new line into the attic space where I could distribute it as needed. I discovered the 1/2" pvc conduit would fit perfectly inside the half-collar fitting on the bottom of the box and could be held in place with a couple of zip ties. I used a couple of 90 elbows as I didn't have room for sweeps and ran the conduit up the wall.
Climbed into the attic with two CAT5 cables where I plan on the home-run location and routed them through the trusses to the hole I made through the siding. (This is the time of year to work in a central Tx attic!). That done I slipped them through the outside conduit and into the box. I left it all unconnected as it was quitting time.
I need to locate a punch-down block and a phone/ADSL splitter to wire in at the home-run location. I have a centrally located closet where the upflow HVAC unit is so I think I'll use a wall inside for it. It will be nice to get this job behind me.
I've removed the lightning arrestor to clean the terminals. The main ground is still attached at the bottom of the brass buss bar. Note the installation of the 1/2" pvc conduit on the bottom left, held in place with a zip tie. Using conduit looks nicer and will protect the CAT5 cable from the elements and Sun.
Here's a close-up of the conduit connection. This looks neater than individual wires/cable exiting. I search for some sort of strain-relief to adapt to this fitting, then realized that the conduit itself might just fit.
A bit dark as I underexposed to compensate for the direct Sunlight. Note the now shiny brass connections.
Ready for hook-up.
1998 Volvo V70 T5 212,455 mi. Original Owner.
#3254063 - 01/20/14 01:49 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
OVERKILL Offline
Loc: Ontario, Canada
Very similar to how I have mine setup. My run is short (maybe 2ft) into my basement, where it runs into a Corning VDSL2 splitter. I'd recommend the same unit for you.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3254068 - 01/20/14 01:51 PM Re: PhoCo Box Clean-Up [Re: OVERKILL]
sleddriver Offline
Loc: Central Texas
Thanks for the advice Chris!
#3254092 - 01/20/14 02:08 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
sleddriver Offline
Loc: Central Texas
Found this page helpful for DIY'ers.
#3254359 - 01/20/14 07:18 PM Re: PhoCo Box Clean-Up [Re: OVERKILL]
sleddriver Offline
Loc: Central Texas
Next time I see an ATT truck in the neighborhood, I'm going to ask if my Demarc Box can be upgraded and an ADSL splitter installed in it. I've heard they do this for U-verse subscribers.
I'll also call ATT tomorrow and ask about getting this upgrade. They may do it for free. Then I could use part of a block for voice and the rest for data.
What do you think?
#3254364 - 01/20/14 07:24 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
OVERKILL Offline
What do you think?
I think that's a great idea. I bought the splitter ($20.00) because Bell wouldn't have done that for me since I don't use their service wink That and I figured I'd do a better wiring job.
Buying a NID with a built-in splitter was a lot more money, so this route made the most sense to me.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3256388 - 01/22/14 02:40 PM Re: PhoCo Box Clean-Up [Re: OVERKILL]
sleddriver Offline
Loc: Central Texas
ATT wants $100 to come out and install one of these splitters in the NID so I told them no thanks. Been calling around locally and can't seem to find them in-stock. Have yet to encounter an ATT truck to ask for one. May not be worth the hassle!
Picked up both a 66 & half-of-a-110 block yesterday. The 66 block is cert 5e and made in the USA by Seimon, the 110 cheap asian. So I'm leaning towards the former. I don't have a basement, so I'll install the block in the HVAC closet. Also wondering if I should move the router into the same area instead of the floor behind the desktop confuser?
I'm looking at maybe three points of distribution: office, kitchen, living room with voice + data at each.
#3256436 - 01/22/14 03:13 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
OVERKILL Offline
Here's the one for inside the NID:
http://www.ebay.com/itm/Corning-SPS-SA1-...=item19e53d8016
Here is the one I have:
http://catalog.corning.com/CableSystems/...0&vid=23291
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3256482 - 01/22/14 03:59 PM Re: PhoCo Box Clean-Up [Re: OVERKILL]
sleddriver Offline
Loc: Central Texas
where did you buy yours? I've called several distributers locally who Corning lists on their website and they don't have a clue nor stock these. Can't even give me a price. It's getting to be more trouble than it's worth. I can always wire the punch block so to add one later as this is holding me up. Thanks for chiming in.
#3256484 - 01/22/14 04:01 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
OVERKILL Offline
My local ISP stocks them, LOL! They are around $20.00.
Can't you just order it online?
They also carry this one: TII 80-410V
Which works just as well.
You could buy it on-line from here:
http://www.shop.dsl-filters.com/product.sc?productId=77
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3256495 - 01/22/14 04:16 PM Re: PhoCo Box Clean-Up [Re: OVERKILL]
sleddriver Offline
Loc: Central Texas
My local ISP stocks them, LOL! They are around $20.00. They also carry this one: TII 80-410V Which works just as well. You could buy it on-line from here:
Wow your ISP stocks them? No joy down here from ATT. I may get lucky if I see one of their service trucks stopped.
I'm not exactly expecting an improvement over what I currently have as its a 10ft piece of Cat5 from the MODEM to the demarc box! So I want to re-route it through the attic and down the wall to replace the old 2-pair. My medium speed dsl 6Mb/sec down works fine for me and is only $20/month. Thanks for the link.
#3256615 - 01/22/14 06:46 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
sleddriver Offline
Loc: Central Texas
Update: Plan C brought me luck...
I decided to go for a bike ride to get away from the confuser and lo and behold, I came across an ATT U-verse truck in the neighborhood. The tech walked up 5 min. later. I asked if he happened to have any of the ADSL splitters that go in the NID and he replied SURE!!
He gave me an updated model of the one I'd been searching for: Tii95S-1-12
He also gave me an AFL DM000535 NID VDSL POTS splitter and mentioned that it probably wasn't compatible with ADSL.
Not sure which is these is 'better' as I don't have VDSL or ADSL+ service. However, my thanks to the generosity of the U-verse installer I came across. So I'm back in business with no further delays. Whoo-Hoo!
#3256758 - 01/22/14 08:30 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
OVERKILL Offline
Fantastic thumbsup Great score! And I would bet either will work fine with your service.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3257304 - 01/23/14 10:36 AM Re: PhoCo Box Clean-Up [Re: OVERKILL]
sleddriver Offline
Loc: Central Texas
The cold Canadian air arrived on-time this a.m. and looks to stay around a few days at least. Now I can get back up in the attic and do some work.
That was a great score. The truck guys have always been helpful.
Cheers2
Cheers & Beers
#3259688 - 01/25/14 01:49 PM Re: PhoCo Box Clean-Up [Re: sleddriver]
sleddriver Offline
Loc: Central Texas
Update:
Decided to go with a 100-pair 66-block for connection/distribution use. I'd also like to mount the ATT-supplied 7550 router next to the 66B for convienence. This will also place it higher off the ground, so signal strength might improve. Maybe. I can easily run a 110Vac outlet as well to provide modem power.
I'd like to distribute a CAT5 cable to each of 5 places. The modem has 4 10/100 ports with RJ45 connectors. From what I understand 10/100 = ethernet, which means it needs all 4 pairs to function. Correct?
So the DATA signal from the DSL splitter in the demarc box is connected to the modem through the 66B. Then the 10/100 ports will each need to be run to 4 of those locations, leaving one out. So I'll need two CAT5 cables to each jack: one containing VOICE and the other 10/100. Correct?
I understand that all LT's now have wireless ethernet cards and maybe still have 10/100 wired ports. But not a DSL modem inside. So I can't feed it a 2-wire DATA line from the splitter and get DSL. Instead it needs either a wireless ethernet or to be plugged into a 10/100 outlet. Correct?
The first round of figuring I thought I'd just distribute VOICE and DATA to each location. But a modem would still be required at that location to enable DSL. Further, these 'isolated' modems wouldn't communicate with each other either.
So if I put the 4-port modem next to the block, then I could distribute an additional cable to each jack and the 4 of them would be on the same network.
Most of the time, I'm using a single desktop plugged straight into the modem and I keep the radio disabled. Occasionally, I light up another desktop to do some Autocad/photoshop work. When I need to transfer files or to print, I plug it into one of the 4 10/100 ports. Nothing in the media center uses ethernet (yet), but perhaps I should plan on a cable there.
I can always have more 10/100 cables than ports, and either get a switch or just move them around as needed. I do have a spare Netgear N150 wireless router (WNR1000) that might be able to be used in dumb mode as a switch, not sure.
Before I start punching the block, I want to lay this all out first. While I can send DATA through the same cable as VOICE to each jack, I'm not sure what good it will do as I'll have to install a modem at that point to use DSL.
What are your thoughts on this?
Page 1 of 3 1 2 3 >
