F1 - 2016 Belgian Grand Prix
by gofast182
08/24/16 07:55 PM
Ethernet card uograde needed?
by NHHEMI
08/24/16 07:27 PM
2012 Suzuki DL1000 VStrom Oil Recommendations
by RHALL
08/24/16 07:24 PM
Audio/Micro Adapter Help
by coopns
08/24/16 07:18 PM
Purolator boss 2222 6,200 miles
by gabriel9766
08/24/16 06:49 PM
Fram Ultra paint peeling
by Run
08/24/16 06:26 PM
Cell phone mount suction cup doesn't stick
by mclasser
08/24/16 06:02 PM
2008 Nissa Versa 110,000 miles second report.
by Datarock
08/24/16 05:07 PM
Best Oils for Direct Injection & Turbo Engines
by BobsArmory
08/24/16 04:45 PM
cheap upgrade to win 10 from win 7 s/n
by bmwjohn
08/24/16 04:25 PM
trimmer loses power when hot
by motor_oil_madman
08/24/16 04:21 PM
NAPA "GOLD" #1358, 10,080 miles CUT OPEN
by car51
08/24/16 04:01 PM
ShadowSix, warfire, Brutus232, gojoneeded, jimmyangst
58911 Registered Users
118 registered (andrewlg, 2015_PSD, 29662, 2002 Maxima SE, Al, 11 invisible), 1736 Guests and 10 Spiders online.
58911 Members
66 Forums
253509 Topics
#3247602 - 01/13/14 10:08 PM Water pump replacement and coolant
mclasser Offline
Loc: The Right Coast
I know these are rather novice questions but here I go--
All the coolant that flows out during a water pump replacement effectively drains coolant from the engine block, correct? So when mechanics say the coolant is replaced as well during a timing belt + water pump job, does this mean they also drain the radiator so you now have nearly 100% new coolant in the system? I've always wondered about this grin.
Edited by mclasser (01/13/14 10:09 PM)
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
2002 Infiniti I35
#3247625 - 01/13/14 10:34 PM Re: Water pump replacement and coolant [Re: mclasser]
bdcardinal Online   content
Loc: Santa Barbara, CA
Most will drain from the radiator so they avoid the mess when you pull the water pump.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#3247630 - 01/13/14 10:41 PM Re: Water pump replacement and coolant [Re: mclasser]
FL_Rob Offline
Loc: gulf coast FL.U.S.
Every block is alittle different but basically it's drained at least to that level, some will remain.When you pop the hose off the WP the coolant is lost unless locking hose clamps are used and or the lost coolant is saved and returned to re-fill it.Thats pretty chintzy though.
#3247655 - 01/13/14 11:28 PM Re: Water pump replacement and coolant [Re: mclasser]
Jimmy9190 Online   content
Loc: Clermont, Florida
When I replaced my water pump I drained the old coolant out by removing the lower radiator hose. Then coolant came pouring out of the block when I removed the pump. My engine has a block drain but I did not open it. There was not much left in the block anyway, it took right at the rated spec, I think it was about 2.5 gallons of 50/50 coolant to water to re-fill the cooling system. I used brand new coolant and water when I re-filled it.
Jimmy9190
2013 Honda Civic LX Sedan
Napa Synthetic 0W20, Napa Gold 7356
#3247690 - 01/14/14 12:19 AM Re: Water pump replacement and coolant [Re: mclasser]
KB2008X Offline
Loc: St. Louis, MO.
If in fact the radiator was also drained, and not everyone does that automatically for various reasons, when the water pump was replaced then anywhere from about 60% to 80% of the coolant may have been drained.
The location of the water pump on the engine determines how much coolant is drained from the engine while changing the pump. Some engines have the water pump lower or higher on the engine than others, therefore more or less coolant is drained out of the engine and cooling system.
As for the radiator being drained, that depends upon a number of factors. One is access to the drain plug or petcock. In some vehicles it is next to impossible to get to, so the lower radiator hose is pulled instead and that is sometimes nearly as effective as draining from the drain plug. Other factors are how much time the mechanic has to do the job, how neat he is, how conscientious he is, what the shop protocol is, etc. In other words don't assume that the radiator was drained, and drained properly, in the course of replacing your water pump.
Even if the radiator was drained when the pump was changed there will still be old coolant left in the engine, and probably in the heater core and various hoses. The only way to get 100%, or even 95%, is to use a coolant change machine, which are often useless and I don't know if anyone still uses them anymore, or repeated cycles of drain, refill with water and running the engine, until the fluid drained out looks like straight water. For my cars I prefer the repeated drain and refills.
It's an arguable point as to whether or not removing 100% of the old coolant really makes a big difference. There are lots of cars on the road with way over a 100,000 miles that have had the cooling system serviced in a half...way manner that are still running fine.
If they made an honest attempt at draining the radiator and refilled with the right coolant you're probably OK.
04 Town Car 4.6 5w20 FL820S
92 Ram D150 3.9 10w30 MO-090
03 S-10 4.3 5w30 Puro L10111
above on TropArtic Synthetic Blend
10 Toyota Camry - undecided
#3247697 - 01/14/14 12:30 AM Re: Water pump replacement and coolant [Re: mclasser]
bvance554 Offline
Loc: VA
Unless you paid them for a coolant flush and refill I would assume they topped it off.
#3247713 - 01/14/14 02:28 AM Re: Water pump replacement and coolant [Re: bvance554]
demarpaint Offline
Loc: NY
For sure, if they did flush and refill you'd see it on their invoice and be charged for it.
God Bless Our Troops
#3247803 - 01/14/14 07:18 AM Re: Water pump replacement and coolant [Re: demarpaint]
motor_oil_madman Offline
Loc: Houston, Texas
Very true. In this case they probably saved the coolant in one of those 5 gallon clean yellow plastic oil change type containers and just refilled it with the original coolant.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#3247807 - 01/14/14 07:27 AM Re: Water pump replacement and coolant [Re: motor_oil_madman]
KrisZ Offline
Loc: Toronto, Canada
Yup, if you did not pay for new coolant it sure as heck wasn't changed, maybe topped off. People like to assume that things just happen all on their own.
Edited by KrisZ (01/14/14 07:28 AM)
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#3247821 - 01/14/14 07:45 AM Re: Water pump replacement and coolant [Re: mclasser]
Tegger Online   content
Loc: Canada
Depends on the engine.
They drain the rad AND THE BLOCK.
On a Honda, if you pull the water pump without draining the block, a quart of coolant will pour all over the engine in the worst possible place once the pump is loose, and make a big mess. So you drain the block as well as the rad before pulling the pump. Once the block is drained, only a small dribble will escape when the water pump is removed.
Don't let ANYBODY tell you that you can change the coolant properly without draining the block. Doing so is a "fudge" performed by home mechanics who are trying to get out of doing a proper job.
2013 Toyota RAV4 - 57,000 miles - Toyota 0W-20, Toyota filter
