gathermewool
Site Donor 2023
After seeing how badly the OEM Subaru blue (Honeywell) filter held up during my last OCI (I've been using them for a while, and could have sworn they started off higher quality,) and based on recommendations, both online and a local Subaru dealer tech (who also owns an H4 turbo Subie,) I purchased an H6 filter for my next oil change.
The filter is larger.
I won't cut it open until after it has been used, so internal construction is unknown.
NO ADBV that I can see. I find this odd, and wonder what the difference between the H6 and every other H4 engine is that it would not require and ADBV.
I've read all of the ADBV posts here on BITOG, so please don't simply reply with, "if it's vertically mounted, no ADBV is required," which I don't believe is true in all cases.
Here are some pics, just in case I'm losing it, but the ADBV should be clearly visible from the inlet holes, right?
