Simple question. Is is possible to replace the non-adjustable main jet on a Tecumseh carb with an adjustable one? I put a new, non-adjustable carb on a HS50 5hp Tecumseh and it ran pretty well for a little while but now it seems to lack some power when it's under load.
I've removed the fixed main jet and cleaned it out good and that helped a little but it's just not up to the power level of when I first installed the carb. I've replaced the fuel line in hopes that maybe it was partially blocked, but no dice.
Now I'm thinking that an adjustable main jet will allow me to richen up the mixture and it would run properly. Can I just replace with an adjustable jet? Thanks.
