They don't advise using it for gasoline. What component composition are you referring to? Thanks.[/quote]
I dunno exactly. Just a disclaimer for the masses. I've used my mighty vac on gas at least 10 times. I just try not to tip it or jostle it, to avoid getting gas up on the valving component.
