PureOne PL14612 on 2013 Mazda3 Skyactiv?
Northeast PA
Amazon says it won't fit. Purolator website says it will fit. Amazon suggests Purolator synthetic PSL14612 and PSL10241 (the 10241 makes no sense to me, the PSL14612 does make sense if PL14612 fits). Purolator website doesn't mention synthetic version as option, just PureOne and classic.
Anyone know? I already own a new PL14612 that I originally bought for our other car, a 2010 Forester , however I also have ~6 Subaru blue OEM that I'm going to use up on that vehicle. Before I start the change in the spring, I'd like to ensure the new filter fits (obviously). This will be first change on my new Mazda , 2L Skyactiv "i".
The 10241 has a UNF-2B thread while the 14612 has a M20x1.5, so completely different there.
What engine code do you have? There are 5 different engine codes for the 2.0 engine. This is the thing that Amazon won't be able to distinguish, but something like Amsoil application guide will. If you have the engine code [7] you would be looking for a Wix 51348 style filter which is the same as the 10241. The following filters are cross referenced to the Wix 51348/Puro 10241.
Wix 51348 replacement oil filters:
AC-Delco AC024
AC-Delco AC030
AC-Delco AC08
AC-Delco PF 53
AC-Delco PF1212
AC-Delco PF1245
AC-Delco PF13
AC-Delco PF13CL
AC-Delco PF13FCL
AC-Delco PF1781
AC-Delco PF2
AC-Delco PF20
AC-Delco PF2056
AC-Delco PF2CL
AC-Delco PF2FCL
AC-Delco PF53
AC-Delco PF53CL
AC-Delco PF53FCL
AC-Delco PF53M
AC-Delco PF54
ALFA-ROMEO 60574554
ALLIANCE ABP/N10G-LF3335
AMSOIL ASF57
AMSOIL EAO57
AMSOIL EAO58
ARGO 12695
ATLAS M-54
AUTOEDGE AL3614
Autolite for Oil Filters AL3614
AUTOPAR FE213
AUTOPAR FE259
AUTOPRO 2348
Baldwin B1405
Baldwin B1430
Baldwin B7020
Baldwin BT223
Baldwin BT8409
Beck/Arnley 041-8077
Beck/Arnley 041-8097
Beck/Arnley 041-8162
BIG A 92269
BIG A 92335
BIG A 92348
Bosch 0986AF1042
Bosch 0986AF1157
Bosch 3330
Bosch 72161
BRAVO B241
BRIGGS & STRATTON 491056
BRIGGS & STRATTON 491056S
BUKH 610J0050
BUNTON BPL6006
CAM2 C241
Canadian Tire 17-1748-8
Canadian Tire 27-5517-0
CARCARE IOF3614
CARQUEST 85335
CARQUEST 85348
CARQUEST 85374
CASE 87409203
CASITE CF2951
CASITE CF3614
CASTROL CAS3614
CATERPILLAR 220-1523
CENEX CO2835
ChampLab LF525
ChampLab PH2835
ChampLab PH7014
CHAMPION OF10
CHRYSLER 2647020
CHRYSLER 4105409
CHRYSLER 4105409AB
CHRYSLER 4105409AC
CHRYSLER 4273810
CITGO C241
CLARK 6513501
CLARK 6513601
CRUISEMASTER 224
CUMMINS C600-211-2110
DEFENSE DL3614
DEFENSE DL9566
DELPHI FX1017
DENSO 115010-2191
DENSO 115310-0261
DENSO 150-1002
DENSO 150-1003
DEUTSCH D366
Donaldson P502016
Donaldson P550335
Donaldson P550589
DYNALIFE CN-3614
Econo Lube L10241
EMGO 10-55600
EMGO 10-55610
EVERGARD E2835
FACET 335
Filters Incorporated OF3614
FIRESTONE TF-335
FIRESTONE TF335
FLAG C-3614
Fleetguard HF28783
Fleetguard LF16011
Fleetguard LF3335
Fleetguard LF3376
Fleetguard LF3460
Fleetguard LF3874
FLEETRITE LFR-83335
FLEETRITE LFR-83460
Flying F PH3614AZ
Fram PH3614
Fram PH6016
Fram PH7575
FSA C1123
FSA C1403
FULLER 4304827
GEHL 000361
GENERAC 070185E
GONHER GP58
GONHER GP58M
GOODYEAR 222-4522
GOODYEAR L335
GRAND PRIX PH2835
Grease Monkey GM10241
Grease Monkey GM335
Group 7 V241
GULF GF-224
HASTINGS HF1000
HASTINGS LF157
HASTINGS LF494
HASTINGS LF525
HASTINGS LF550
HASTINGS LF563
HASTINGS LF589
HAVOLINE T-29
IAPCO A-0211-001
IAPCO OF2
IAPCO OF36
IAPCO OF935
INGERSOLL-RAND C25042
INGERSOLL-RAND C25402
INGERSOLL-RAND C26191
INGERSOLL-RAND C37568
IPD 10130
ITM 11-10103
ITM 11-11400
ITM 11-11516
ITM 11-17600
ITM 11-19700
ITM 111-0103
ITM 111-7600
ITM 111-9700
ITM 111-9802
JAGUAR C2Z 21964
JIFFY LUBE HL3614
JIFFY LUBE JL241
JIFFY LUBE L10241
K MART K-16
K MART MP-16
K & N HP-1002
KENDALL K17
KOHLER 52 050 02
KOHLER 52 050 02S
KOHLER 520-5002
KOHLER 5205002
KRALINATOR L127
LAZORLITE L11-1350
LAZORLITE L11-1805
LEE LF-2835
LEE LF-2835HP
LISTER-PETTER 201-55370
LUBER-FINER P823
LUBER-FINER PH2835
LUBER-FINER PH2858
LUBER-FINER PH7014
Lucas Girling F6515
Lucas Girling F6587
Lucas Girling F6618
Magneti Marelli 1AMFL00004
Mann Filter ML 1003
Mann Filter W711/80
Mann Filter W712/37
Mann Filter W712/38
Mann Filter W712/43
Mann Filter W811/81
Mann Filter W920/80
MARATHON PH2835
MARATHON-LETOURNEAU PH2835
Master Parts PH-2835
Mechanics Circle MOF 3614
MELROE 6652366
MICROGARD MGL3614
MIGHTY M3614
MILEGUARD MO3614
MINIT LUBE PH2821
MOBIL L35098
MOBIL M1-102
MOBIL MO241
MOPAR L-335
MOPAR MO-409
Motor Trend ML3614
MOTORCRAFT EFL910
MOTORCRAFT FL 793
MOTORCRAFT FL 910
MOTORCRAFT FL 910S
MOTORCRAFT FL-910S
MPA 2050
MPA 2818
NAPA 1269
NAPA 1348
NAPA 1374
NEW HOLLAND 507107
NEW HOLLAND 87415600
NEW HOLLAND SBA140517020
OE+ OF-530
OE+ OF-550
OE+ OF-830
OMC 5031411
OMC 778885
ONAN 122-0406
ONAN 122-0645
ONAN 122-0679
ONAN 122-0800
Parts Master 61215
Parts Master 61348
Parts Master 61391
Parts Plus PH2835
PENNZOIL PZ-21
PERFORMAX PO-21
PERKINS 140517000
PHILLIPS 66 PO241
POWER FLO SL10017
POWER FLO SL10241
POWER FLO SL20252
PRECISION TUNE OF-161
PRO/GAUGE PGO-241
PRO-TEC 130
PROMOTIVE PH241
PRONTO PO-3614
Purolator L10241
Purolator L14477
Purolator L35098
Purolator ML16816
Quaker State L35098
Quaker State QS3614
Repco ROF58A
ROCKHILL 61348
ROVER LR025306
Ryco Z172
Ryco Z418
Ryco Z87A
SAAB 30 54 8485
SAAB 91 44 445
SAAB 93 18 6554
Sakura C1123
Sakura C1403
SEARS 45205
SECURITY SO-241
SELECT 500 L1348
SERVICE 1 OF241
SERVICE PRO M241
SHELL L35098
SHELL SH29
SIEG OS3614
SIERRA 18-7884
SIERRA 18-7915
SIERRA 18-7915-1
SILVERLINE 21348
STP PH7014
STP S3614
SUNOCO O-21
SUPERTECH ST3614
TARGET SF2835
TRUST PH2835
UNIVERSAL 299381
UNOCAL PF2835
UNOCAL PF9A
VALUTEST 42143
VALUTEST V2348
VALVOLINE VO25
VERA 10-01337
VERA 10-01352
VERA 10-01402
VERA 10-50389
WALMI WS-3614
WARNER PH2835
WARNER PH7014
Wesfil WZ172
Wesfil WZ418
WESTERN AUTO 74-5884-7
WHITE 33-0083836
Wix 51348
Wix 51762
Wix 51785
Wix 57023
Wix 57181
YAMAHA 69J-13440-01-00
YUGO 46620004
YUGO 46624209
ZINGA BE10-18
OE Part numbers matching this oil filter:
Daihatsu 15601-87103-000
Ford 1S 7Z 6731 DA
Ford 1S7G-6714-DA
Ford 1S7Z-6714-DA
Ford 1S7Z-6731-DA
Ford BE8Z-6731-AB
Ford USA 1S7Z-6731-DA
General Motors GM 19160689
General Motors GM 19160690
General Motors GM 19161274
General Motors GM 19161275
General Motors GM 21000872
General Motors GM 25011520
General Motors GM 25014441
General Motors GM 7984778
General Motors GM 89060466
General Motors GM 89060498
General Motors GM 94840078
General Motors GM 96058042
General Motors GM 9975120
John Deere AM101207
John Deere AT1220338
John Deere HE1220800
John Deere TCA10018
Komatsu 600-211-2110
Kubota 70000-36160
Mazda LF05-14-302A
Mazda LF05-14-302B
Mazda LF10-14-302
Mazda LF10-14-302A
Mazda LFY1-14-302
Mitsubishi MD308302
OEM 1651083000
OEM 9091520002
Suzuki 16510-05A00
Suzuki 16510-60B01
Suzuki 16510-60B10
Suzuki 16510-60B11
Suzuki 16510-73000
Suzuki 16510-73001
Suzuki 16510-73001-000
Suzuki 16510-73002
Suzuki 16510-73002-000
Suzuki 16510-82001
Suzuki 16510-82703
Suzuki 16510-83000
Suzuki 16510-83010
Suzuki 16510-83011
Suzuki 16510-83012
Suzuki 16510-87J00
Toyota 00120-00009
Toyota 00120-00012
Toyota 00120-00014
Toyota 08922-02004
Toyota 08922-02010
Toyota 08922-02011
Toyota 15601-13051
Toyota 16510-83011
Toyota 32623-12620-71
Toyota 32670-12620-71
Toyota 90915-03002
Toyota 90915-03005
Toyota 90915-20001
Toyota 90915-20002
Toyota 90915-20003
Toyota 90915-20004
Toyota 90915-YZZA1
Toyota 90915-YZZB1
Toyota 90915-YZZB5
Toyota 90915-YZZB9
Toyota 90915-YZZD1
Toyota 90915-YZZD3
Toyota 90915-YZZG1
Toyota C0120-00014
Toyota C0120-00015
Volvo 834337
Volvo 834337-8
Volvo Trucks/VCE/VME/PENTA 834337
VW Group 04E 115 561B
VW Group 7B0 115 561
http://www.oilfilter-crossreference.com/convert/Wix/51348
If the L14612 fits the application, then the PL and PLS versions should also fit. The same goes for any purolator filter as far as i know, if one fits, then all of the same number should fit.
Looks like it depends on the VIN series number in the 8th digit/(place).
Vin # 8 (or #7) uses the 14612/6607 Puro/Fram size. Other letters F&G use the 10241/3614 size.
So check the eigth digit of your VIN to decide which size is correct. I suspect it's the 14612/6607 size.
Thanks guys. I think we are headed in right direction. According to Amsoil:
http://www.amsoil.com/products/vin_code_lookup.pdf
Its the 8th character, which is a P , the 9th character is an 8...sheesh.
So Purolator doesn't have a recommendation since P is not listed. 8 is listed though...
For P engine code Amsoil recommends:
"No Recommendations"
For 8 engine code:
EA15K12-EA
Not going to buy Amsoil oil/filter just using it to help find right filter, I short trip a lot, in cold, no extended OCI for me also under warranty still..
For Purolator filters...Still stuck...
Ok, I just found a youtube for the 'first time oil change for 2013 Mazda 3 Skyactiv 2.0L' which I won't link to because of language in video. But, the guy bought the 3614(10241) which mid-video he found out was the wrong filter. Then he went and purchased the correct 6607/14612.
Based on the yt, confident the 6607/14612 is correct.
Wouldn't be too upset at Purolator as even the Fram look up uses the VIN code number/letter but doesn't explain how to find it. As this is kind of new, the look up will get better with time.
Originally Posted By: KD0AXS
I'd just take a look and see what filter is on it now, and cross reference it to a Purolator.
Brand new Mazda oil filter from factory, no indicator.
Watched that as well. You are right, if Fram filter finder or Purolator told us how to tell 8 from F or G we''d know for certain. I guess I'll wing it with the 14612 I have on hand and see what happens.
Actually the Puro look up seems to be down right now, at least it is for me.
But, I found another 2.0L Skyactiv diy yt that showed the Mazda OEM filter part number(PE01-14-302), plugged it into the Fram xref look up, result 6607. PL14612 it is. No worries.
For 8 engine code:
EA15K12-EA
You should still consider Amsoil OE oil then. Low price, OEM interval. PC price gets it under $5/qt, case price lower.
Amsoil OE 0W-20 - Product Code OEZ
I would just go with the SkyActic OEM filter on a new engine until the 2d party manufactures get it sorted out. To nice an engine to Guess which filter will work IMO. Ed
I'm going to make a trip to the local dealer to see if they use/sell them. IIRC the sales guy said they use Castrol so not sure they will use OEM filters but I will check. Good advice, I use Subaru OEM filters on the other vehicle.
Originally Posted By: bourne
PSL14612/PL14612/L14612/PH4612 all work great in our 2012 2.0 Skyactiv Mazda 3.
That is good to know. Looking like 14612/6607 is the prevailing thought.
I'd now say not only the prevailing thought, but the correct answer to the question first asked. There is now the OEM part listing number posted twice, once in my previous post here and once above. And, the OEM part number clearly crosses to the 6607/14612 and is listed as such on the Fram look up. In the Wix it is the 57002 (a new Wix filter application) which actually does list a P code as the same application as 7&8 Vin#.
Now if you choose the to use the OEM PE01-14-302 that's fine. But the spec'd aftermarket oil filters are the 6607/14612 and Wix 57002.
Thank you, I missed that in your first post.
