Originally Posted By: Shannow
Dad's R16 said to only use Castrol GTX 20W-50, but the Ford stuff I photoed today is pretty equal opportunity...Mobil SHCID was my fave gear lube...but they stopped making it.
Could they possibly have recommended a more diverse set of brands of fluids on that one manual page? Denso compressor oil, Mobil axle fluids, Texaco transfer case fluids, and Castrol engine oils. On the part you cut off, did they recommend Prestone antifreeze or Zerex? How about some Pentosin PSF and some ATE brake fluid?
There's nothing wrong with 15w-40, at least if other options are too expensive. A 15w-40 with the right specs can still have a very high TBN.
Note that up here at the distributor, Delvac Elite 222 0w-30 synthetic in a 5 gallon pail is barely more money than a pail of Delvac 1300 15w-40, at least when compared to the difference between synthetic and conventional at normal retail outlets.
My distributor offers Delvac 1 at near conventional prices. Now, for a real laugh. I had to stop at Walmart last night. VR-1 is cheaper than VWB, PYB, GTX, QSGB, and just about everything else you can think of.
