Engaged
by LoneRanger
06/24/16 04:49 PM
What stores still carry quality US-made fuel hose?
by JHZR2
06/24/16 04:25 PM
Looking For A New Natural Gas 6 Burner Barbecue...
by crazyoildude
06/24/16 04:25 PM
Autolite spark plug rebate
by Need4racin
06/24/16 04:20 PM
Can Am Spyder
by Panzerman
06/24/16 04:17 PM
Prototype photo shows off Tesla Model 3 interior
by HTSS_TR
06/24/16 03:13 PM
Strange Brake Behavior
by jkasch
06/24/16 03:09 PM
Schwinn Suburban 1895-1995
by otis24
06/24/16 11:15 AM
Need to run virtual Windows 10 on Linux Mint
by Alfred_B
06/24/16 10:21 AM
Pump says octane is min. rating, any tests?
by KGMtech
06/24/16 10:02 AM
Beachcraft Premier Flight
by Drew99GT
06/24/16 09:51 AM
Purolator ADBV tears
by mazdamonky
06/24/16 08:46 AM
Koloa, codeman021, chryslerconcorde, VolCntry73, OilyWaterMIXER
58254 Registered Users
76 registered (901Memphis, 2010Civic, AnthemBassMan, AandPDan, 123Saab, andyd, 6 invisible), 1761 Guests and 14 Spiders online.
58254 Members
66 Forums
250752 Topics
Page 2 of 2 < 1 2
#3070441 - 07/19/13 04:34 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: crazyoildude]
fdcg27 Online   content
Loc: OH
For any given amount of light output, the LED will use less electricity. This is why they've become common in even low-end flashlights.
LEDs live much longer lives than CFLs as well.
So, the LED is probably worth its higher upfront cost.
As these lamps become more common, cost will decline.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3072822 - 07/22/13 08:54 AM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: fdcg27]
HerrStig Offline
Loc: Boston, MA
+1
#3078897 - 07/28/13 02:18 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: HerrStig]
whizbyu Offline
Loc: Carolinas
I always look at labels. Incandescent bulbs are made in the USA. CFL and LED's are ALL made in China. Someone explain to me how LED's cost soooooo much more than other bulbs. Every component of LED bulbs are made in China. If CFL's are going to be made obsolete because of Mercury issues, why then are the utility companies giving them away?
#3082005 - 07/31/13 02:41 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: whizbyu]
gogozy Offline
Loc: GTA, Ontario, Canada
you can find low wattage LED run off 12v and that would further reduce heat and energy lost (from 120v->12v transformer). plus you have an option to hook up a solar panel and battery.
wattage difference between led and cfl are very little in low light output.
#3090161 - 08/08/13 08:58 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: whizbyu]
BearZDefect Offline
Loc: Lexington, KY
Originally Posted By: whizbyu
I always look at labels. Incandescent bulbs are made in the USA...
Not anymore from what I've seen. It has been years since I've been able to find good old Made in the USA incandescent bulbs. First they went to Mexico, then to China.
#3090469 - 08/09/13 08:31 AM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: BearZDefect]
HerrStig Offline
Loc: Boston, MA
+1 Sylvania closed a big bulb plant in the midwest several years ago.
#3106217 - 08/26/13 02:51 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: whizbyu]
NateDN10 Offline
Loc: Rochester, NY
OK, sure. Have you ever looked into wholesale bulk LED (just the diode, not the whole fixture) pricing? You're going to be paying several dollars for the diode alone. Then there's the power circuitry, as LEDs can't be run directly off of 120V AC. And last, there's the heat-sinks. Even though LEDs are more efficient than incandescent bulbs, they still give off heat. And unlike CFLs, that heat is concentrated in the relatively small area of the diode. So they need heat-sinks to dissipate the heat.
2005 Chevrolet Cobalt - 100,000 mi.
2012 Mazda5 - 87,000 mi.
#3152555 - 10/11/13 03:54 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: crazyoildude]
CBR.worm Offline
Loc: Jupiter, Fl
I have changed almost everything in my house to LED. I had a number of CFL's that lasted longer than incandescent, but a couple of them burned up (literally) and they always take a long time to get bright and ultimately they die. As they failed I replaced them. I have CREE, Philips, eBay and others - all of mine are dimmable. I haven't had an LED bulb fail yet, many are going on 4 years old (when they were much more expensive). I go for the warm white ones - virtually identical color to incandescent.
My biggest issue is that a lot of my dimmers don't work without an incandescent attached. So if I have ten high hats on a dimmer, one has to be incandescent.
'06 Infiniti G35 Sedan 6MT - 160k
#3153252 - 10/12/13 10:29 AM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: NateDN10]
wsar10 Offline
Loc: PA
This is not the case with the diode itself......the LED itself cost parts of penny's when you buy 20,000 of them at a clip. go to mouser.com and look for your self. We order them by the skids at work.
other than that I agree with your post.
The issue I have had with A/C LED lights is simply the quality of workmanship, the diode itself is probably rated 25-40k hours but the rest of the circuit WILL fail prematurely, in my experience.
I would just stick to CFL's, the cost on the part itself makes the CFL cheaper (not including the electricity savings)
$2/8000hr=0.00025 CFL
$20/25000hr=0.0008 LED
98 JEEP ZJ, 5.2 T5,WIX
03 Jeep WJ, the famous 4.0 T6,WIX
93 Jeep XJ, the famous 4.0 T5, WIX
01 Dakota, 3.9l T5,WIX
07 Explorer, 4.0 GC 0-40,WIX
11 KIA
#3183477 - 11/09/13 11:50 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: wsar10]
TBirgensmith Offline
Loc: PA
There are many costs associated with manufacturing that we often overlook. The cost to tool-up a production line (or to build a new factory), the cost of labour, the cost of utilities, et cetera. These costs are always passed on to the consumer, and it is the early adopters who pay the most.
On a bulb-technology note, CFL's are absolutely useless in outdoor fixtures this time of year, at least around here. We have used one (75W equivalent) on the outside of our detached garage for at least two years, but we have to swap it for a good ol' incandescent in the winter; the CFL will not warm up if left on from dusk until dawn.
85 626 133k: M1HM 10W-40, M1
00 Millenia 163k: M1AFE 0W-30, M1
01 E-350 99k: MC 5W-20, MC
05 Accent 102k: M1EP 5W-20, M1
13 Civic 5k: M1AFE 0W-20, M1
#3183533 - 11/10/13 06:25 AM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: TBirgensmith]
Pop_Rivit Offline
Loc: Midwest
Interesting. I have compact florescent bulbs in some of our outdoor lights and they're just fine, even in the middle of winter and in temperatures around 0 (F). At that temperature it takes about a minute to come up to full brightness, but that's not a problem for us since they're usually left on when we leave, or they're on when we're expecting someone to come home.
#3183875 - 11/10/13 01:55 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: crazyoildude]
ARB1977 Offline
Loc: North Texas
One thing I've learned is that LEDs work better on dimmer switches. In open fixture applications both CFL and LEDs hum with dimmers as well.
2015 Tacoma 4.0L 30K (as of 5-24-16)
Mobil One EP 5W30 / Toyota filter
2008 CRV 2.4L 144K (as of 04-13-16)
Maxlife 5W20 / Fram TG filter
#3216905 - 12/14/13 09:58 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: stockrex]
crazyoildude Offline
Loc: New Jersey
Led lights run cooler than the others almost cold at least that is what i thought...i just put my hands on one that was on all night and it was cool im not sure about the inside
#3290089 - 02/21/14 10:25 PM Re: L.E.D. Light Bulbs Or Compact Florescent Bulbs ? [Re: crazyoildude]
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
My Cree 60's are great! Silent, instant, nicer colors. Look mor like a 'bulb' and none of the mercury I believe. The have dazzled me. Realizing the CFL is just a stepping stone of technology.
Such a thing as a 15k oil change or a lifetime transmission fluid!!??
Page 2 of 2 < 1 2
