Originally Posted By: oldhp
Ethanol is hygroscopic, it "attracts" moisture. You don't want that. Ethanol is JUNK.
What you want is either methanol or isopropanol, it mixes with and breaks down the big bubbles of moisture and lets it go thur fuel system alittle at a time.
Look up HEET and what is in it and how it works you'll see the difference.
ZERO ethanol for me anytime I can buy it.
Ethanol does attract moisture, but only the moisture that is in the tank. It isn't like the stuff has a neon sign outside the vehicle calling out to moisture in the air to come join the party.. And even though it does attract moisture in the tank, it bonds and so the moisture does not freeze and just passes on thru. And it has been rightly stated, methanol has a corrosive effect.
I have used ethanol blends from E10 thru E85 since the late 70's here in the upper Midwest where the atmosphere holds a fair amount of moisture and it gets into serious sub zero territory during the winter. No one I know in my area, nor myself, has had an issue related to ethanol use.
Oldhp, I would think, living in the area you do, you would have a similar experience and not fall for the anti ethanol hype.
