13Tacoma
Thread starter
Originally Posted By: dnewton3
13Tacoma -
Presuming you are going to follow the OEM maintenance plan, then just about any decent brand name filter will do a fine job. Most of them are a tad more efficient than the OEM filter, but that really does not make any difference.
Use the filter makers site to get a correct interchange, and be done with it. If warranty coverge is important to you (and I would think it is for a 2013MY), then I'd stick to the proffered products and not venture off the reservation. If you select an unauthorized filter, then the burden of proof is upon you, should anything bad happen. Use their recommended filter, and the weight is upon them.
The dealer changes the oil for me every 5000 miles until I hit 25000 miles. Then I'm on my own but have to adhere to their maintenance plan to still be covered under warranty. I really would like to eventually push my OCI up since I'll be paying for it at that point. I think a 10,000 mile OCI would be great.
Onto the point of after market filters being a tad more efficient. Does that mean they flow better or they filter better? And which would be preferred when doing longer OCIs than the manufacturer recommends?
13Tacoma -
