13Tacoma -
Presuming you are going to follow the OEM maintenance plan, then just about any decent brand name filter will do a fine job. Most of them are a tad more efficient than the OEM filter, but that really does not make any difference.
Use the filter makers site to get a correct interchange, and be done with it. If warranty coverge is important to you (and I would think it is for a 2013MY), then I'd stick to the proffered products and not venture off the reservation. If you select an unauthorized filter, then the burden of proof is upon you, should anything bad happen. Use their recommended filter, and the weight is upon them.
