I have an older Teac AG-V1020 in our entertainment center. I have always had two bookshelf speakers hooked to it, a pair of older KLH speakers that put out good lows, but poor highs. I want to add a set of set of speakers for highs to help fill in. I have speakers from a Panasonic boombox I was playing with these weekend. The KLH speakers are of an unknown impedance (though probably 6 ohm or thereabouts) and the Panasonic speakers are 2.7 ohm.
The Teac receiver is designed for 4-16 ohm impedance.
There are two sets of speaker outputs on the receiver, A and B. If both are selected, it says that it runs them through the surround sound circuit in the receiver (I have the Teac owner's manual). With the Panasonics connected to the A outputs and the KLHs connected to the B outputs, I heard only the Panasonics. It's like the KLHs weren't even on. When I turned A speakers off, then it's like the B speakers turned on and I could hear them then. So I got to looking at running both speakers from the A output.
It appears to me that I want to connect the speakers in series...that is:
+ on the Teac to + on the Panasonic speaker
- on the Panasonic speaker to + on the KLH speaker
- on the KLH speaker to - on the Teac
If I connect them in series, the impedances are additive, right? So my total impedance would be the 2.7 ohms on the Panasonic speaker plus whatever the impedance is on the KLH speaker; say it's 6 ohms...it'd be 8.7 total ohms, right? Which would be fine.
But if I connect the speakers in parallel, that is the +/- inputs on the Teac going to both the +/- input on the Panasonic speaker and the +/- input on the KLH speaker, then the total impedance is reduced by the inverse of both, right? It would be in THIS situation that I could burn up the amplifier in my receiver unit due to too much power being sent to the speakers, right?
I am pretty clearly not looking for an audiophile system here...just something with a little more balance (the KLHs are good on lows only) for when we're watching a football game or a movie.
Thanks!
Thanks!
