Finally removed my rear calipers so as to make sure everything was sliding properly. The pads were, but they got greased anyhow; two of the sliders were dry though.
But, I found the bolts just a bit hard to remove... The manual that I downloaded indicated 65ft-lb is what these bolts should be tightened to. Three of them required hitting the 17mm wrench with the jack handle. The fourth refused, and required the big hammer.
I put some of the brake lube onto the threads of the offending bolt, and spaced out on doing anything other than "good n tight" (which is probably not far from the required level).
1. Good/bad? Maybe I should remove and use real anti-sieze on the threads?
2. Why on earth do I have to hammer them off? They were installed about 7 months ago by the dealership.
I recall having to hammer the bolts off an Isuzu just like this; maybe import trucks require hammers for this job?
I glanced at the fronts but decided those looked more complicated than anything I've seen thus far.
