0W20 in the US but 5W30 outside US for Mazda
by perryg114
02/05/16 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
02/05/16 08:48 PM
why would someone want to pay with a phone?
by turtlevette
02/05/16 08:16 PM
The connection was reset problem
by Triple_Se7en
02/05/16 08:14 PM
BIG PROBLEM!
by Avery4
02/05/16 08:03 PM
11,000 miles on a BMW
by BigJohn
02/05/16 07:48 PM
Thoughts on 2007 Nissan Sentra 60K for a used car?
by ToyotaNSaturn
02/05/16 07:20 PM
Anyone else have "See Cashier" issues with Shell?
by SLO_Town
02/05/16 07:16 PM
Shear rates in engine components...
by Shannow
02/05/16 06:32 PM
Windows Live Mail Question
by Wingman
02/05/16 06:21 PM
Royal Enfield Himalayan....Giddy Up!
by BigJohn
02/05/16 06:17 PM
clear no tint 1994 dakota windshield?
by bmwjohn
02/05/16 06:14 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
92 registered (AMC, 2015_PSD, Astro14, 77GrandPrix, aquariuscsm, 19 invisible), 1324 Guests and 127 Spiders online.
56834 Members
66 Forums
244290 Topics
#3196292 - 11/24/13 04:37 AM Gasoline diesel engines
Exhaustgases Offline
Loc: wa
I'd like to read some stories about this. Real stories that is.
#3196340 - 11/24/13 07:09 AM Re: Gasoline diesel engines [Re: Exhaustgases]
skyactiv Offline
Loc: The Midwest
You OK? http://www.steelsoldiers.com/showthread.php?30821-Are-all-Dueces-Multifuel/page2
Me: 13' VW GTI 3 door 6 speed manual
#3196376 - 11/24/13 08:09 AM Re: Gasoline diesel engines [Re: Exhaustgases]
fdcg27 Offline
Loc: OH
There are two possible scenarios.
One would be using diesel in a spark ignition engine.
This is common in parts of the world where diesel is more readily available than gasoline, like Cuba.
You start the engine on gasoline and then switch to diesel after it warms up. This works with old, low compression engines.
It might not work as well with more modern engines, since diesel has very low octane.
The second possibility would be a compression ignition engine using gasoline as a fuel. This has been tried as well and there is some serious work going on to evaluate such designs for production.
Of which were you thinking?
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3196450 - 11/24/13 09:08 AM Re: Gasoline diesel engines [Re: Exhaustgases]
Cardenio327 Offline
Loc: Oaxaca, Mexico
About 20 years ago a neighbor had a large antique Farmall that started on gasoline and ran on diesel. Had two levers that had to be moved at the same time to switch it over. If I understand right one of the levers closed off auxiliary combustion chambers with poppet valves increasing compression and shutting off vacuum flow through the carburetor. The other lever apparently started the direct injection of the diesel fuel.
One time he went by the house being towed. Every time he tried to start it, it veered for the ditch. He had mistakenly hooked the power steering hoses up backwards, and the electric starter didn't have enough force to turn the motor that way.
'08 Honda C90ST Super Cub 10w-40 PYB
'08 Honda NX4 Falcon 5w-40 Delo 400LE
'09 Honda Fit LX 10w-30 QSUD
'99 F-150 W/T 4.2L 10w-30 QSUD
#3319374 - 03/21/14 08:49 PM Re: Gasoline diesel engines [Re: Exhaustgases]
artificialist Offline
Loc: Florida
In David's Farm, he operates an engine that can use gasoline and diesel fuel.
http://www.youtube.com/watch?v=Y81EUqzvbWc
Unfortunately, it appears that it can't be run at full power on gasoline.
The idea was that the compression could be lowered in gasoline mode, and that would make the starter do less work. Also, gasoline engines from back then would fire up more quickly than diesels.
2010 Lancer Ralliart Sportback
#3909899 - 11/06/15 11:04 PM Re: Gasoline diesel engines [Re: Exhaustgases]
jmaster Offline
Loc: ann arbor, mi
and then there were gasoline compression ignition engines.
here
01 Mustang Bullitt mobil5k 5w30-break-in, Redline zdp Bosch D+, AMS ATF, Torco 80w90 RGO
97 E350ext 7.3PS 4.10 gears|Mag 1 5w40 syn LM mos2, Bosch D+
