Code:
Blackstone Comments:
This is a nice second report from your Jetta's 2.5L engine. Most metals have improved a bit
since last time, as we would expect for an engine as it matures through the first few oil changes. The high
copper last time was probably a little residual wear-in that has now all but washed out of the engine. You
might see a few ppm of improvements next time, but ideally, from here on out, you'll see pretty steady
readings. The viscosity was fine, and the TBN was good at 3.9. No fuel, moisture, or coolant was found. Try
up to 9,000 miles next time. Nice!
Code:
OIL Mobil 1 0w-40 Castrol 5-40 (?)
MILES IN USE 7,769 5,295
MILES 24,117 16,348
SAMPLE TAKEN 10/2/2013 1/5/2013
ALUMINUM 3 3
CHROMIUM 0 0
IRON 16 20
COPPER 7 14
LEAD 0 1
TIN 0 0
MOLYBDENUM 69 1
NICKEL 0 1
MANGANESE 5 6
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 4
BORON 107 42
SILICON 7 9
SODIUM 1 21
CALCIUM 2955 2457
MAGNESIUM 20 32
PHOSPHORUS 831 842
ZINC 988 1
BARIUM 0 0
INSOLUBLES 68.4 0.2
WATER 0 0
FLASHPOINT ºF 440 380
SUS VIS 210ºF 68.4 64.4
cSt @ 212ºF 12.52 11.44
TBN 3.9 4.6
Code:
MILES 24,117 16,348
ALUMINUM 3 3
CHROMIUM 0 0
IRON 16 20
COPPER 7 14
LEAD 0 1
TIN 0 0
MOLYBDENUM 69 1
NICKEL 0 1
MANGANESE 5 6
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 4
BORON 107 42
SILICON 7 9
SODIUM 1 21
CALCIUM 2955 2457
MAGNESIUM 20 32
PHOSPHORUS 831 842
ZINC 988 1
BARIUM 0 0
INSOLUBLES 68.4 0.2
WATER 0 0
TBN 3.9 4.6
