I started a topic on vague recommendations, but I suppose this one has me stumped.
For my wife's 2002 Civic, the recommended ATF change period is 120,000 miles or 10 years. Now this is where the fun starts. I don't think it's ever been changed and my wife doesn't remember having this done.
The owners manual says that to do a "thorough flush", they recommend 4 complete drain and fills. The manual is odd - it says do it three times and then a final time. But then it says it should be "drained and refilled" according to the maintenance schedule. But it doesn't specify if this is a single drain and refill or the "flush" as they describe it.
Quote:
http://owners.honda.com/assets/OWNERLINK/Model/own_man/2002CivicSd.pdf
To thoroughly flush the
transmission, the technician
should drain and refill it with
Honda ATF-Z1, then drive the
vehicle a short distance. Do this
three times. Then drain and refill
the transmission a final time.
The transmission should be drained
and refilled with new fluid according
to the time and distance recommen-
dations in the maintenance schedule.
Now if I had owned this car from the start, I probably would have done a single drain and fill every 30,000 miles. That may not be absolutely necessarily, but it would make me feel better.
And the M18 crush washer is $3 at a Honda dealer. Not sure why the huge price difference compared to an otherwise similarly made M14 washer for oil changes. I even remember when Honda autos drained out of a bolt that took the same crush washer.
