Originally Posted By: Exhaustgases
Don't really want to do a full syn, on a high mileage trans. But then I suppose what ever the expensive Toyota stuff is its probably a full syn.
Well if its HIGH MILES
Get the VALVOLINE MAX LIFE
Lots of people here use it with many types of trannys and talk very highly about it.
Its a FULL SYNTHETIC and made for Transmission with HIGH MILES
Read specs
Product Information
A PRODUCT OF VALVOLINE
MAXLIFE
DEX/MERC ATF
Valvoline MaxLife
DEX/MERC ATF (Automatic Transmission Fluid) is the first fluid of its kind that is specifically formulated for
the
broadest range of
today’s technologically sophi
sticated automatic transmissions. It is formulated with
synthetic
base stocks,
unique seal conditioners, long
life friction modifiers, special anti
wear additives, and shear stable viscosity modifiers, among other
components
to fight the four major cause
s
of transmission breakdown:
leaks, slippage, shudder and gear wear.
Valvoline has conducted
extensive
in
house testing, independent lab testing, and field
testing to support MaxLife ATF performance
in the broadest range of transmissions; however, it
shou
ld be noted
that
MaxLife ATF is not a OEM licensed product. The r
espective
vehicle manufacturers have neither evaluated nor
endorsed
MaxLife ATF in these applications.
If an OEM licensed product is
preferred we recommend Valvoline DEXRON® VI, Valvoline AT
F+4® and Valvoline MERCON®V for the
corresponding applications.
The Valvoline
MaxLife
ATF
Advantages:
Synthetic fluid
Conditions transmission seals to prevent leaks
Reduces varnish formation and wear
Our best
anti
shudder performance
Improves and maintains smooth shifting longer than conventional automatic transmission fluids
Superi
or anti
shudder performance
Provides excellent flow properties at low temperatures and greater film protection at high temperatures
Maximizes the life of higher mileage transmissions
Performance Levels
Suitable for use in:
Ford
MERCON®, MERCON®V, M
ERCON®SP and MERCON®LV applications
GM
DEXRON®
II, DEXRON®
III and DEXRON®
VI applications
Nissan/Infiniti
Matic D, Matic J, Matic K, and Matic S applications
Mitsubishi
Diamond SP
II and SP
III applications
Hyundai/ KIA
SP
II, SP
III, SP
IV and SPH
IV
applications
Subaru
ATF and ATF
HP applications
Toyota/Lexus
Type T, T
III, T
IV and WS
Honda/Acura
ATF
Z1 (except in CVTs) applications
Allison
C4 and TES
389 applications
Mercedes Benz
NAG1 applications
Volvo
passeng
er car applications and STD 1273.41
Volkswagen
TL52162
