I was recently given an off-brand automotive power pack for jump starting a car.
It did NOT come with the charging plug. The battery is "moderately" charged. The front of the pack has "low", "moderately", and "fully" charged LED's, and the middle light illuminates when you press the TEST button.
I went to Walmart and bought a universal battery charger that had the correct plug on the end. According to what I could find online, the charger should be 12V and 500milliamps. I found a 600milliamp unit. I plugged it in for 12 hours. The charger is still stuck on the "moderately" charged mode. I don't think the charger did anything.
Can I use a regular battery charger to re-charge this unit? Has anyone ever tried this?
On this unit, there are 2 button on the back that you press in to "activate" the jumper cables on the unit. I haven't done this yet, but when you press these buttons (to complete the circuit from the battery to the cables), I was thinking I could hook a battery charger to the jumper cables on the unit and therefore, fully charge it.
Anyone ever try this?
But perhaps when I depress the "activation" buttons on the rear of the unit, they will only stay depressed for a short period of time. I'm not sure.
What you all think? I only have one battery charger, and it's a nice digital unit. So I don't want to fry it trying to work on something that was given to me....that I may never use.
