2015 Silverado - Put some chrome
by Realtech214
05/02/16 10:22 PM
Ticks!
by spasm3
05/02/16 09:54 PM
shop didn't replace clamps on steering rack
by motor_oil_madman
05/02/16 09:46 PM
First SSD on Xubuntu 16.04
by Eric Smith
05/02/16 09:20 PM
Purolator Boss PBL25277
by Quattro Pete
05/02/16 09:11 PM
Pan w/ drain plug for 62TE
by JTK
05/02/16 09:04 PM
2007 Explorer 4.0 upper and lower intake gaskets.
by ls1mike
05/02/16 08:55 PM
Cars... where they belong: On the road!!!
by Spillips
05/02/16 08:29 PM
I got 'spoofed' !
by Geauxtiger
05/02/16 07:57 PM
2013 Camry DIY Brake Fluid Replacement Experience
by windeye
05/02/16 07:26 PM
Pics Husky 525LS ran on XP oil
by Buzzsaw
05/02/16 07:09 PM
Brake Pad and Rotor opinions
by oilstudent24
05/02/16 07:02 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
22 registered (Farmer, 01_celica_gt, ajchien, carlprop, Atesz792, Dykkerdahl, 1 invisible), 631 Guests and 320 Spiders online.
57779 Members
66 Forums
248388 Topics
#3130567 - 09/20/13 10:50 AM 90K IR sparkplug change 2012 Eantra
schuylkill Offline
Loc: Pennsylvania
Coming up on 90K mi. and I want to replace my plugs, aluminum head. What are opinions on whether the head should be warm or cold when removing the old plugs? I've never had these high mileage plugs before and I'm a little concerned about getting them out.
91 Civic LX 170K Maxlife Hyundai OE
98 Civic CX, EX tranny 630K Maxlife P1
09 Elantra 26K Pennzoil Plat OE
12 Elantra GLS manual 131K Toyota bulk?
#3130580 - 09/20/13 11:02 AM Re: 90K IR sparkplug change 2012 Eantra [Re: schuylkill]
ARCOgraphite Offline
Loc: N.H, U.S.A.
If you are planning on replacing them with NEW immediately - you want that engine stone cold. OTW they might come out easier from a warm head. You shouldnt really see any issue cold, as the OE plug will have likely be plated to resist seizing and the threads are almost than twice as long as in the "old" days.
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3130600 - 09/20/13 11:27 AM Re: 90K IR sparkplug change 2012 Eantra [Re: schuylkill]
SteveSRT8 Offline
Loc: Sunny Florida
WE have routinely gone well beyond factory limits in our fleet without misfire or codes. And the plugs still come right out, don't fall for the line that they automatically cannot be removed.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3130613 - 09/20/13 11:43 AM Re: 90K IR sparkplug change 2012 Eantra [Re: SteveSRT8]
Hokiefyd Offline
Loc: North Carolina
+1 to this. My first spark plug change in an aluminum head was with a 1997 Cadillac Seville, with over 140,000 miles on the original plugs. They came right out, no thread issues, no installation issues. A few months ago, I replaced the spark plugs in our 2005 Acura MDX with the same miles as what's on your Elantra, with no removal or installation issues.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#3130624 - 09/20/13 11:58 AM Re: 90K IR sparkplug change 2012 Eantra [Re: schuylkill]
Miller88 Offline
Loc: Onondaga County
I changed the spark plugs on my 36000 mile Focus a few weeks ago. I got a crunch when breaking them lose, but they came out and went back in.
I changed with the engine stone cold. Was probably one of the easiest spark plug changes I have ever done!
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
#3130736 - 09/20/13 02:04 PM Re: 90K IR sparkplug change 2012 Eantra [Re: schuylkill]
Bottom_Feeder Offline
Loc: Occupied Virginia
Cold! Like first-thing-in-the-morning cold.
#3130790 - 09/20/13 02:40 PM Re: 90K IR sparkplug change 2012 Eantra [Re: schuylkill]
sciphi Offline
Loc: Upstate NY
Stone cold engine, and be very careful torqueing the new ones in. The crush gasket will crush first, then go for final torque. The new plugs do not need to be much more than hand tight. IIRC it's 1/8 turn past hand-tight. That will ensure the threads in the head are secure without being too tight.
2009 Honda Fit Sport
2012 Chevrolet Cruze Eco
#3131075 - 09/20/13 09:17 PM Re: 90K IR sparkplug change 2012 Eantra [Re: sciphi]
The_Eric Offline
Loc: Iowa
It depends on the plug configuration. Tapered seat is usually 1/16 of a turn and gasketed plugs are typically 2/3s to 3/4ths of a turn when new.
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#3131181 - 09/21/13 12:19 AM Re: 90K IR sparkplug change 2012 Eantra [Re: Hokiefyd]
bvance554 Offline
Loc: VA
I thought i was bad with 148k on the original plugs in my subaru. They came out very easily.
#3131217 - 09/21/13 02:38 AM Re: 90K IR sparkplug change 2012 Eantra [Re: schuylkill]
mclasser Offline
Loc: The Right Coast
You shouldn't encounter any problems since the plugs have only been in since 2012 (90k miles in such little time is crazy!).
I replaced the original NGK plugs in my 02 Accord at 166k miles and they came out so easily it was scary. If you are really concerned, remove the plug boots or coil packs (whichever your car has) the night before and soak the plug cavities with some penetrating oil. Then you should totally be good the next morning when the engine is cold. I'm really bad at "feeling the torque" so I bought a simple beam-style torque wrench from Sears and used that torque the new plugs.
Edited by mclasser (09/21/13 02:40 AM)
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
2002 Infiniti I35
#3131286 - 09/21/13 05:49 AM Re: 90K IR sparkplug change 2012 Eantra [Re: schuylkill]
schuylkill Offline
Loc: Pennsylvania
I bought the car in June 2011 but yeah it's way too much driving.
I have the new NGK plugs but from the discussion here I think I'll wait until the 100K to do the install. That's what the plugs are rated and from other reading I've done the IR plugs don't lose their gap. I like to try to keep things in good shape for max fuel efficiency and for keeping it going "forever." However I also like to be eco minded and use things as long as they are good to go.
