Originally Posted By: thrace
There is reason why DW-1 might not always be a good replacement for Z-1. However Z-1 is not a good solution either for old Hondas with its low heat resistance and other factors. DW-1 has lower viscosity than Z-1. This could cause issue with torque converter overheating. Sonnax states that "under certain conditions, the flow of TCC release/charge oil is low enough to allow the TCC piston to drag on the cover. When the TCC piston is dragging on the cover, heat is being generated and friction material wear is accelerated, leading to the 740 code."
And "Honda converter charge oil comes from the charge oil circuit of the main regulator valve. With this design, charge pressure is often only half of what line pressure would be."
Lower viscosity would cause lower pressure and greater probability of torque converter overheating.
thanks, this is a good information to know. I worry this is reason Honda issue a transmission software update on 2007-2009 MDX in 2012, as Honda starting to use DW1 in 2011. Has Maxlife also has less viscosity compare to 4 or 5 years ago.
