I dragged this beauty from VA to all the way to MA. It had not been started in few years.
Keen eye would notice the binder clip on the spark plug. The boot wire was completely chewed by critter and it was hanging by few strands. The boot broke off there. Few strands which were left, I twisted them and put them over the plug and put the binder clip to hold.
It took us over an hour of yanking to get it to start. Even when it was firing, it would run for half a second and quit. Eventually, I remembered how mechanics used to nurse a carburetor when I was a kid back in India. I removed the cylindrical air filter element and put my palm on the intake. By judiciously controlling the air intake, I was able to get it to stay running for few minutes and then it was able to run on its own with the air filter hooked up. I had Gumout Regane in the gas and let it run for a while.
Loaded it up in the van and got to MA and when I tried to start it back home, I had the same problem i.e. once in a while it would fire but quit instantly. I shot some carb cleaner through the throat and eventually got it running. Once it was running, I had no problem restarting it. I believe intake gasket has a leak because when I spray carb cleaner around the linkage area, the idle went up.
I have tried to google this model but did not find any information on it.
By the way, this was purchased in 2000 and was only used one season. BIL said he used to start it once in a while but looking at it, I don't think it was started in this decade. The battery is shot and even after charging it for 16 hours, it was only at 11.3V
Any redneck way to fix the spark plug boot? Can I at least find the replacement coil (which will have its own boot) cheaply?
I think I have traded one set of problems for another with this one. Here are the pictures
