Originally Posted By: FXjohn
Originally Posted By: OnTheFarm
This is a great thread, I'm glad I found it. I've been on a mission to defeat undercarriage rust for many years. I've tried them all and I have become fairly educated in the products. Below is my opinion.
a) Carwell, Krown, oil, etc. all will do the job to a certain extent. If you shield a metal surface with
anything, it will prevent corrosion for a certain time. The problem I had with most of the products, is that they are almost all "solvent based", and that makes them very thin and waterlike, and very drippy. Now when the solvent (alcohol, mineral spirits, etc) evaporates you are left with a semi-dry wax-like coating. And that's fine. It will protect any area's that it has reached
before it dried. It's done migrating into other areas. Also if it gets scraped off by something in the road or during repair, it will leave a bare unprotected spot.
Krown and Rust Check both don't dry. They are thin oil. My Lincoln was last done like 4 years ago and the Krown that's on it is still a liquid and STILL creeps out between the trim pieces.
It is also still wet on the frame rails on our Expedition.
I only have two complaints with Krown:
1. On vehicles with pre-existing corrosion, it appears to wick/soak into the corrosion making reapplication in those areas necessary after a bit.
2. The dripping/creeping can get annoying when it is burning off your exhaust or on your driveway.
pretty unrealistic complaints
Perhaps I should have said "things to watch out for"
