It seems to me that if a well respected company like Lubro Moly makes an idle only engine flush, then it could be a very harmless and potentially effective maintenance item.
I have an engine which I believe is clean but it did require fuel system cleaning and if I understand it right, incomplete combustion also finds its way into the crankcase.
So which brands of engine flush would you recommend as being safest and most effective?
