Originally Posted By: Kira
Excuse my ignorance but cutting fresh sipes into a worn tire sounds like a trick done by unscrupulous used car dealers. Is the rubber thicker there to allow deepening the sipes? Kira
Sipes are sometimes not all the way down in the tread, especially on all season type tires. So if you look at a half-used tire it suddenly looks very "plain" when the fancy sipes have worn off.
If they cut sipes all the way down, like on some snow tires, you get a lot of tread squirm, as I understand it. This wears out tires faster and makes them handle worse.
So if you could go in somehow and resipe things when half worn, as the theory goes, you'll get something back.
Big commercial tires sometimes have really thick rubber under the tread, which allows deeper regrooving, but that's a different subject.
