Originally Posted By: ionbeam22
Lucas makes a high ZDDP additive. According to lucas "Addition of 16 oz. to 4.5 quarts motor oil will achieve approximately 5,000 ppm of Zinc."
http://www.lucasoil.com/products/display...B%20Zinc%20Plus
For my self, I trust the chemists at (Mobil, Ashland, Shell etc) to know what they are doing, and so I would just use high quality synthetic oil, and if I felt some need to fool around with it, maybe add some Lubro-moly MoS2 additive.
5000ppm of zddp is waaaaay too much and would be corrosive at that point if there wasn't something else added to combat the issue.
I don't even bother with zddp additives. Its cheap,and yesterday's tech. If I am going to add something its going to be a friction modifier,either mos2 of a polymer type add.
Originally Posted By: Triple_Se7en
The most benefit to using an entire 16oz bottle of CD-2 Oil Treatment (Gray bottle) is relieving oil usage not caused by exterior gasket leaks.
I've used this stuff for 3-4 years now and it really works. Upon oil drain, the reddish tint is indicative of alot of moly.... looks/feels eerily similar to the old VSOT (Valvoline Synthetic Oil Treatment) that alot of posters raved about.... myself included. VSOT is currently discontinued by Valvoline.
My most recent fix was on a 2001 Olds Alero 3.4. My daughter purchased it with 64K and it was using a full quart every 1K. The next three oil changes I used Pennzoil High Mileage oil with a bottle of CD-2 Oil Treatment. Each OCI saw less oil usage. Now at 80K using Pennzoil Platinum and I haven't added a drop of oil in 4K. I plan to change-out the oil at 6K.
Just remember this! The CD-2 yellow bottle is NOT the same stuff. All the national chain stores sell the yellow bottle. Very few sell the gray bottle tonic.
Right on. I'm all for stop leak adds but the only additives I buy are lubro-moly products,and good ole mmo.
Where are you getting the info that moly is red. The inorganic type(mos2) is black and the organic type is clear
But I'd like to read about red moly so if you could steer me in the right direction please
