After years passing by of not working on carbs, I rebuilt the carb on my 1997 4.3L Mercruiser engine last fall and ran it up and down the lake once. It appeared to work well. Last week I took the boat out for the first time of 2013. It started and ran well. If it was shut off for a minute or two, it would fire right up. After being shut off for more than 30 minutes, it is difficult to start. No fuel smell and it doesn't look flooded when I remove the air filter / spark arrestor. I have yet to try to fix it, but was thinking float level, mixture or maybe even the fuel pump (getting weak causing vapor lock, though the yellow tube does not smell like gas). I was wondering if anyone else has had this problem or if anyone has any suggestions.
