Own a Mbenz 1988 300sel w126 and need opinions or advice on the use of Seafoam. These cars are notorious for rough idle and or surging idle. I do know about the fuel pressure regulator and that it can also cause similar symptoms but I'm thinking I should try the cheapest method first and then start checking everything else.
The following are the symptoms at start up on a cold morning:
1. Key ignition turned and car engine begins to turn, starts, but then immediately turns off. If you repeat everything the next morning but this time press on the gas pedal(accelerator) the car starts up fine.
2. After starting, and after maybe 20 or so seconds the car begins to run with an erratic idle. I guess we can call this a "rough" idle also.
3. After about 5 minutes the surging or erratic idle continues without stopping.
4. After driving 20 minutes on the road and finally reaching or getting to a STOP, I continue to feel the rough idle and observe the RMP's go up and down and then observe the OIL PRESSURE gauge go slightly up and down. Car has not turned off on me on this type of routine driving.
The following are the symptoms at start up on a hot sometimes very hot day:
1. Turn key and attempt to start car. Cars engine turns and turns and turns and as I apply the gas pedal the cars engine turning gets faster and faster and then finally starts.
Whats your take on these symptoms and can Seafoam correct these symptoms. I saw a Youtube video, with the exact same symptoms, showing a 300se and Seafoam. Looks like it worked
http://www.youtube.com/watch?v=NDWzlCt5s5g
What are the negative effects?
