I've wondered why big, slow, diesel engines are common, and gasoline engines tend to run much faster. For instance, a diesel-electric locomotive might have an engine that runs flat-out at 900 rpm. Big diesel trucks commonly shift at 1800 or so rpm.
In comparison, the Ford GAA, which is kind of a big, slow gasoline engine, would rev to 2600-2800 rpm in stock trim, and the International 549, one of the last big gasoline truck engines, would rev to 3400-3600 rpm. And I shouldn't forget the GMC 702 V12 making 250 hp at 2400 rpm.
But then, there are the diesel behemoths like the Wärtsilä-Sulzer RTA96-C, which powers container ships and tops out at 102 rpm, running on heavy fuel oil.
Why are there no modern gasoline giants? Or are there some that I don't know about?
